Question about Motorola Mobility H730 Bluetooth Headset
Motorola H730 does not pair with phone
The headset cannot be recognised by any bluetooth device
SOURCE: Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Posted on Jan 21, 2008
ziraffa
  • 827 Answers
SOURCE: Sony Ericsson not recognising motorola n356 headset re bluetooth.
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
rockfixya
  • 679 Answers
SOURCE: motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
timthorne911
  • 464 Answers
SOURCE: pairing ny bluetooth headset with cellphone
it's always 0000
Posted on Mar 18, 2009
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
When trying to pair my H730 with my phone I get the message "can't communicate with Motorola H730".
Sometimes pairing is hard but your phone especially Bluetooth device to your phone cell phone to not recognize your Bluetooth device may not pay very well with some phones I recommend a universal Bluetooth earpiece has high capacity to go with any model carry your phone1 only get you one or two
Oct 09, 2016 | Motorola Mobility H730 Bluetooth Headset
I cant connect it to my new Galaxy note 4
Irma
Turn on Bluetooth on Galaxy Note 4 via settings Bluetooth. Then H730 Pair and Connect
Mark
Motorola Support
Mar 09, 2015 | Motorola Mobility H730 Bluetooth Headset
Why motorola h730 blue light stays on
It is wanting to pair with your phone. Pair with it and then it will blink.
Jun 26, 2014 | Motorola Mobility H730 Bluetooth Headset
How do i turn on the headset?
Open the boom. It will start to blink and then change to blue if it isn't paired to a phone. if it is paired and a known device is in range it should connect.
Mark
Motorola Support
Apr 28, 2014 | Motorola Mobility H730 Bluetooth Headset
Motorola h730 not connecting
Are you putting the headset in pairing mode? THe light must be steady blue to pair.
Mark
Motorola Support
Mar 18, 2014 | Motorola Mobility H730 Bluetooth Headset
How do I sync my phone with the H730?
Turn off H730,
1) have you ever paired the H730 to any other devices? if so make sure those devices are turned off.
2) Next make sure that your phone has bluetooth featured turned on.
3) Turn on the H730, if there is no devices that the H730 headset can pair to, it should go into descovery mode, the headset light should turn a steady blue, and you should hear "ready to pair"
4) At this point go to your phones bluetooth options and search for bluetooth devices. The H730 should show up
5) It then should ask for a password, 0000
6) after entering the passcode the H730 should say pairing complete
Make sure that it is fully charged, usually takes about an hour to charge completely.
Mar 11, 2014 | Motorola Mobility H700 Wireless Headset
Motorola h730 after factory reset will not stay paired after closing and opening again
Delete the pairing on the phone and then re-pair. Also ensure your headset is fully charged. It should autopair with your phone after a reset when you open boom if phone has bluetooth turned on and is in range.
Mark
Motorola Support
Feb 10, 2014 | Motorola Mobility H730 Bluetooth Headset
Windows driver drivers
You may need to manually search for drivers online. Some of the newer computers don't have things automatically installed.
Mark
Motorola Support
Jan 31, 2014 | Motorola Mobility H730 Bluetooth Headset
H730 not pair with iphone
Ensure that the H730 has steady blue light. Then have iPhone search for headset.
Mark
Motorola Support
Jan 20, 2014 | Motorola Mobility H730 Bluetooth Headset
Motorola Mobility H730 Bluetooth Headset Logo
414 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
