Question about Goodman Heating & Cooling
I have a goodman model#GMH80703ANAA SERIAL#0607148632 -I HAVE NO MANUAL AND WAS WONDERING WHAT THE LOW FIRE ON GAS VALVE IWC SUPPOST TO BE SET AT. AND WHAT THE HIGH FIRE IWC PRESSURE SHOULD BE SET TO.I do work for arapahoe county ,and a lisenced furnace tech.
  • 499 Answers
I have done this 34 years and never need to know this . simply replace the $15 part to see if it works, labors not cheap and its better value to the customer for you to sawp it out on a call even if its not bad yet as they are 1 of the weak links that you know will fail . if it doesnt work, which i never saw except when the orifice on the induced draft housing was carboned up! or 1 time the induced draft squirrel cage was disintegrated with the motors shaft left spinning nothing and doing nothing as toinducing any draft! threw mw as the motor was working! and orifice clear and new switch but still not working!!! had to be the cage or poltergeist lol!
Posted on Feb 25, 2012
5 Suggested Answers
  • 96 Answers
SOURCE: My GOODMAN furnace GMH80703ANAA Starts but quits 5 seconds later
You have a flame sensor that may just need cleaning take out and take fine sand paper or emery cloth and clean
Posted on Nov 30, 2008
  • 230 Answers
SOURCE: goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Posted on Jan 29, 2009
  • 15 Answers
SOURCE: Goodman furnace fires up but turns off soon after (over and over)
check grounding and make sure flame sensor is nt dirty .
Posted on Jan 24, 2010
Testimonial: "I cleaned the flame sensor, and that has seemed to do the trick! No problems since then. Thanks!"
rickead1
  • 1998 Answers
SOURCE: I have a goodman GMPN1 gas furnace It goes through
have you checked the pressure switch and also to assure that the flu is clear? can you light the burner with a match and when you do how long does it run for? have you checked the clearance to the burner have you also assured that where the ignitor is pluged into is cleaned ive also noticed on another site there is a board issue with this model have you checked the board ? also have a look at this site as well its where I usually talk with other techs about issues they have with the goodman as well as other units http://www.contractortalk.com/f6/goodman-80-furnace-brand-new-wont-start-7006/ please message me back with the answers to the questions that I have asked and I await your reply Thanks again Rick
Posted on Jan 31, 2011
How the thermostat wires hooks up on the air handler its a Goodman
Include the model and serial for accurate results, that being said the standard wiring is RGYW (C)
R= (red) low voltage power from the transformer to "R" on the thermostat
G= (green) to "G" on the thermostat to the fan relay
Y= (yellow) to "Y" on the thermostat to the AC contactor (relay) coil. (usually outside in the AC unit).
W= (white) "W" on the thermostat to the heating terminal/gas valve, controller (varies with manufacture).
C= (common) not used much these days but some thermostats have to be "powered" by the low voltage transformer because they have lights, rechargeable batteries or other functions that require power.
Oct 25, 2017 | Goodman Heating & Cooling
Goodman serial numbers
Serial numbers are visible on equipment where you see a permanently attached tag.
The tag will also give model number, motor amps, and other information.
Should say serial number or ser. no.
Jun 30, 2014 | Goodman Manufacturing Goodman R410A 14...
Keeps freezing
low air flow or low on refrigerant.
Jul 24, 2013 | Goodman Heating & Cooling
Gas furnace model # gmb100-4 will not fire up ignitor working clicking sound afterwards but no firing up. Whats wrong
If induced draft motor comes on then ignitor tries to light but no flame I would change control board.I've had the same problem on several goodman heaters and all but one required new board. The other one was a bad gas valve but I would try board first. Hope this helps. Thanks
Nov 07, 2010 | Goodman GMS90703BXA Heater
GMNT080-4B Goes into lock after 20 minutes or so of operation
Hi jump out the presure switch see if it lights check fan control is clean at the back of it check air filter is clean
Feb 22, 2010 | Goodman GMS80904BNA Open Flame Mid-Size...
Goodman model GMH95 no high heat
Some questions for you, did you adjust the Low stage gas pressure first and is is about 6" W.C.? Then did you adjust the High stage and is that about 10" W.C.? If the gas pressure is correct and the dip switch is on 2 stage, the unit should fire on both low and high fire for about 5 seconds then drop to low stage. If it does not, check the hoses going to the pressure switch for a leak. Test the high pressure switch when the unit tries to go into high stage to see if it is closing. Do not blow into the hoses or you will need new pressure switches. If it proves a closed switch, you will need to check for voltage at the gas valve. If you get none, replace the circuit board. If you get 24 volts at the orange wire hooked to the Hi side of the gas valve, you have a bad gas valve.
Oct 20, 2009 | Goodman Heating & Cooling
Nov 30, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
