Question about Samsung SGH J150 Cell Phone
Some where my wap download got hang in my set and it occupied my space in hand set need to clear it
  • 380 Answers
You can try these in case you downloaded corrupted or incompatible Java midlets or other media, which are causing problems with the phone
*2767*WAP# Wap Reset
Please contact your network provider in order to obtain you WAP settings.
They will kindly give you the necessary proceedings in order to activate your WAP Settings on your phone.
Posted on Feb 24, 2012
Just bought 2002 astra sxi 16v timing belt snapped within 10 minutes of buying is the engine knackered
Pssible. If the valves and pistons overlap , i.e. occupy the same space at different times there is a hich probability that when the belt smapped they came together. This results in bent valves and damaged piston crowns usually Valves can be replaced and pistons, if they are just grazwd, can be cleaned up a little and lift alone thereafter. If the two sets of components have come together with some force , and the result is a lot of damage, it could be costly.
On the other hand the components might not overlap, they may never occupy the same space at any time. Such engines are called safe, or non interference engines.
Hope it is not too bad
Jun 05, 2015 | Cars & Trucks
Phone loads the whole time without starting up
Install the application like Clean Master. It can be downloaded from google play store. It will clean the memory as well as the occupied space. Occupied spare and memory could be the reason of mobile hanging or late operation issue.
Enjoy !
Mar 16, 2015 | Sony Ericsson Xperia pro MK16i Black
I have an Xbox 360 and I need more space what do I have to do for more FREE space
Many of Xbox 360 gamers have a 4GB hard disk space and as we play different games on Xbox 360, a lot of updates, patches, temporary files are generated. As time passes by, you might not be playing that particular game any more but the space is still occupied.
So in this How to series today, we will learn how to clear up some space on your Xbox 360. Just to make sure, this process will not remove any of your Console Updates or any downloadable content or DLC from your Xbox 360. Also, it will not remove any gamertag which you have created on your console or any saved games which you have played.
Steps :
  • Go to System Settings > Storage. This will list down all the storage Hard Disk, USB or anything else.
  • Select one of the storage and press Y on your controller.
  • This will open up the device option which allows you to Rename, Format, Clear System Cache & Transfer Content.
  • Select Clear System Cache and it will clear the cache for all the storage on your Xbox 360.
It basically start the System Maintenance of Xbox 360 so make sure you do not turn off the device in between. Depending on various factors it may happen in few seconds or couple of minutes.
Just remember that it will remove game updates also and if you play a certain game for which the update was downloaded, you will be prompted again.
Video :
Apart from this, look for games which you do not play any more and delete them. Most of the times space is occupied by trial games which you had downloaded before and forgot to delete it.
Apr 02, 2014 | Video Game Consoles & Games
Hello, I get INSUFFICIENT Memory error when i try to connect to sites on the internet through my samsung champ GT3303i .. Please help on how to fix the same
hi! nothing to worry! i think that you are using phone's defaul browser for browsing and all ur phone memory is occupied ur previous internet cache! first of all try to clear cache in ur browser! then exit all ur unwanted applications that uses phone memory and block browsing! then install browser's like ucweb or opera and many more browsers in ur memory card and set all that browser's cache, download to memory card! then change the installed browsers setting's that u want to acces the internet! that's it! ur problem solved! additional information for u! ucweb is available in wap.ucweb.com and opera is available in m.opear.com! rate me if u like!
Jul 17, 2011 | Samsung GTC3300 Cell Phone
During software update N73, the phone does not switch on. what can i do????
reset your phone using three finger method
follow this instruction :
Turns off the phone
Press simultaneously on the green/talk, 3 and* keys and hold the 3 keys.
Turn on your phone
Wait for the onscreen Format message then can release the three keys
This method may also work for Nokia phones that won't turn on.
Note that before making a reset on Nokia's latest phone
using the *#7370# or the 3 finger method, better make a backup, as you will automatically delete important data:
The license for pre-loaded contents (music, video, maps,etc..)
Mar 11, 2011 | Nokia N73 Cellular Phone
Need instructions for the game count across by Cadaco
Count Across™ Instructions
OBJECT OF GAME
The first player to place four chips in a row, either vertically, horizontally or diagonally wins the game.
Contents
1 Wooden Tray with Content Holder 1 Clear Plastic Slide with holes
1 Two-sided Number Board
25 Purple chips 25 Green chips 1 pair of dice
Set-Up
Each player selects a set of chips (purple or green). Decide which side of the number board to play, Addition Only (blue side) or Addition & Multiplication (red side). Line up the Number Board underneath the Clear Plastic Slide so that the numbers line up through the holes. The raised tab on the Clear Plastic Slide should be face up. Slide the Number Board and Clear Plastic Slide into the Wooden Tray together. The Number Board should rest underneath the Clear Plastic Slide. Each player rolls the dice once to determine who plays first. The player with the highest roll goes first (Player 1).
Addition Only Play
The Player 1 rolls the dice and adds the two numbers on the dice. Places one of your chips on the Number Board over an empty number space that matches the total of the dice.
Example: A play a rolls a 5 and a 3. 5 + 3 = 8
Player 1 finds an empty number 8 space on the Number Board and places a chip into that slot. Player 1 may choose any open 8 on the number board, but may only place one chip on the board per turn.
Player 2 then rolls the dice and places a chip in a space on the number board that matches the total of the dice. Play continues back and forth until one player gets 4 chips in a row, horizontally, vertically or diagonally. A player can remove an opponent's chip from the board in the following instances:
• If a player rolls doubles, they may remove an opponent's chip if it occupies a space that matches the total of the dice. Example: A player rolls a 4 and a 4. 4 + 4 = 8 and if an opponent has a chip in an 8 space on the Number Board, the player may remove the opponent's chip and replace it with his or her own chip.
• If a player rolls the dice and there are no empty spaces matching the total of the dice, the player may remove an opponent's chip that occupies a number space that matches the roll (if only the player's chips occupy those spaces). Then the play ends.
Addition & Multiplication Play
The rules are identical to the Addition Only play, except on each roll players may choose to either Add or MUltiply the numbers rolled. Example: A player rolls a 5 and a 3. The player may do one of the following:
• Add the dice together (5 + 3 = 8) and place a chip over an empty 8 space on the number board
• Multiply the dice (5 x 3 = 15) and place a chip over an empty 15 space on the number board
Warning! Do not throw out the Content Holder. It serves as a platform for the number board as well as storage for the chips and dice.
Jun 19, 2010 | Cadaco Count Across Game
My N73 phone has problem.Its memory always states "NOT ENOUGH MEMORY TO PERFORM OPERATION DELETE SOME DATA FIRST.I already deleted many datas like pictures and music..but it is still the same. please help...
My N73 phone has problem.Its memory always states "NOT ENOUGH MEMORY TO PERFORM OPERATION DELETE SOME DATA FIRST.I already deleted many datas like pictures and music..but it is still the same. please help me.
Jan 05, 2009 | Cell Phones
To free hard disk space
is the 100Gb divided into 2 partition?
since you have done the show all folder and files. and nothing else show up. you can do a defreg. to compress the drive. you may have lots of fragmented files. (that account for the lost space).
Nov 13, 2008 | Computers & Internet
Tips and tricks
tips & trics is inbuilt in the fon in general tab of the settings in setup wizard.....
Jul 29, 2008 | Sony Ericsson K800i Cellular Phone
I bought the phone second hand without the guide
U have to activate wap service bycalling ur service provider, get settings of wap for ur handset.U can open wap sites only.
Sep 10, 2007 | Samsung SGH-E370 Cellular Phone
Samsung SGH J150 Cell Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
