Question about HP OfficeJet 6110 All-In-One InkJet Printer
Remove and check cartridge
I have put new ink cartridge in but this message is still showing
  • Anonymous Oct 30, 2008
    cartridges won't align
  • Anonymous Oct 31, 2008
    My problem is very similar - even though I replaced the HP 15 with an HP 15 - the printer is insisting that it is the wrong cartridge!
    Novelist:
    Scholar:
  • 111 Answers
For "Guest" who posted on October 30th; try clicking on the following link and going through the troubleshooting suggestions on the HP.com web page:
Cartridge Alignment Troubleshooting
As far as replacing a cartridge and getting a "remove and check" error message, there is more to it (at least sometimes) than having the correct cartridge. If it isn't inserted just right, the electrical contacts between the cartridge and the print carriage will not be complete, resulting in an error.
Also, if there is some ink or other matter on the contacts of either the cartridge or the print carriage, you can get the same result.
Try gently removing the cartridge and putting it back in, making sure that you've got a good contact and the latch that holds the cartridge in is correctly engaged. If that doesn't work, click on the link I posted above and follow Step three: "Perform a ink cartridge cleaning procedure". See if that helps.
Quick question for "Guest" who posted on October 31st; you are using an HP 15 cartridge? I own a 6110 all-in-one and use 56 and 57 cartridges. The product doesn't call for a HP 15. Do you have a 6110v or 6110ix?
Post back your results. Good luck.
Posted on Nov 03, 2008
It keeps showing the message "remove and check the right ink cartridge". we already removed and re-install it many times. we also cleaned it and we still show that message. help! thank you!
Try to replace the ink cartridge with a new name brand ink jet cartridge that matches the manufacturer. Sometimes aftermarket ink jet cartridges don't work as well as the name brand ones.
Dec 18, 2010 | Office Equipment & Supplies
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
Replace all ink cartridges at the same time.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon Pixma MP530
I am in the same situation. When 'Check Ink' comes up, the yellow cartridge blinks.  If I take it out and put it back again, the printer will work.  Then after a while on idle mode, the problem will show up again.  Pretty annoying.
WF
Sep 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
154 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
