Question about GE WBSR3140DW Top Load Washer
Wont spin When its done drainig the motor kicks but stops right away I dont know whta it could be.
  • 1,543 Answers
If your washer pumps out but then the motor attempts to start repeatedly and rapidly, you have a bad motor. Please don't rate this, as anything but a FixYa drops my rating.
Posted on Oct 28, 2008
My servis tumble dryer wont spin i have had a look and the belt hasnt snapped and the motor is still working
Do you hear the motor turn on when you start the dryer? If the belt is loose then it could cause it not to turn.
1. If you are able to run it with some of the housing removed, then do that and verify where you are losing your ability to spin.
- Make sure the motor is engaging and actually turning the belt. If it is turning and moving the belt, check to make sure the belt is routed correctly and not slipping on any of the pulleys. If it is, then it may just be time to change the belt.
- If the motor does not spin, listen to the motor and see if you can hear it kick on when you try to start a cycle. If you don't hear anything, turn the power off (unplug from the wall to be safe) and disconnect the connection to the motor. Use a voltmeter or multimeter and connect the probes to the two pins that provide power to the motor (can't say which ones specifically. There may be a service wiring diagram tucked away inside the dryer houseing somewhere.) Plug the dryer back into the wall try to start a cycle which observing the meter. If you are getting no voltage then the motor is not getting the signal to kick on, which means it is some kind of controller device (timer switch, selector switch or control board depending on your device) or a relay. If you hear the motor kick on but won't spin, there are a couple things you can try (unplug the dryer first for both): 1) Take the belt off the motor pulley and try to move it by hand. If it doesn't move smoothly then it could be seizing internally and needs to be repaired or replaced. 2) Disassemble the exhaust housing and check for any small items that may have snuck in past the lint filter somehow. If a small item made it's way past the filter it could jam itself in the blower assembly (which is most likely driven by the main motor) which would either cause the motor to fail or a belt to fail. Either way, **** out all the lint within the exhaust system while you have it open as it's good practice! :)
- Refering to the service wiring manual (which may be tucked away inside the control panel housing) is key. If the motor is not kicking on then you need it to trace its path for power and the signal to turn on. If it is turning on and moving, it's a matter of finding which physical piece is failing (which can be hard to do online).
- If the drum spins easily by hand then it's most likely in the hardware that transfers the energy from the motor to the drum. If it doesn't spin very easily, you may want take the drum out and check for any objects that may have wedged in between the drum and the housing. Also check the plastic shims and cloth gasket to make sure they have not worn excessively. Lastly, make sure the drum has not warped at all.
Dryers are fairly simple machines. Let me know how it turns out for you.
Oct 22, 2012 | Dryers
Lg front loader not drainig, error code comes up.
Humming usually means that the motor is being physically prevented from spinning. Check that there isn't a small coin or similar jammed in the impeller blades...The motors on those pumps also can collect debris INSIDE the pump motor behind the impeller seal..That would require a new pump motor. Check impeller first!....Good luck.....Nomess
May 12, 2010 | LG WM-2277HW Front Load Washer
My washer stops after rinse and kicks out will not spin
You have a bad motor. Your motor turns in ine direction to wash and the other direction to pump and to spin. Sorry.
Please rate solution
Aug 24, 2009 | Whirlpool Washing Machines
Washing machine wont spin
Maybe something is physically preventing the drum from spinning, causing the motor protection to kick in and stopping the machine.
I'd check this out as a first step before calling a repair man:
1) unplug the machine from mains
2) make room between the rubber gasket and the drum for your hand/arm to reach down into the bowels of the machine, in the compartment between the drum and the bowl (or whatever you call it). If you find something strange there, remove it.
I've done this on occasion and have found lots of obstructing objects that don't belong there. Most notably hardware from underwire bras I might add... :)
It is worth a try.
May 21, 2009 | Ariston Technologies Washing Machines
My washer wont go into high speed spin
You probably have a broken motor coupling, take off the cabinet, the pull the pump and motor. the coupling is right there just replace
Feb 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag > Performa > Drains,Rotates, Fills but wont spin
I had the same problem with you a couple days ago. I disassambled the whole machine and i found out that the belt worn out and the motor also losen so i am looking for parts to replace.
Sep 05, 2008 | Maytag Performa PAV2200
Bosch wont spin
go back inside it and look at the place where the drive connects to the drum is there anything loose or missing that should be attached the drive coupling breaks or comes loose, i dont know about this particular model if its a belt driven or what but look closely at the connection to the drum and see if anything is abviously loose or broken.
Dec 20, 2007 | Bosch Classixx WFC 2465 Front Load Washer
GE Spacemaker No Spin
the washer has carbon brushes on the motor if these are low the drum will not spin it needs these carbons to make contact with the motor
Aug 12, 2007 | GE WSKS2060WWH Top Load Washer
Washing machine
Certainly you could find some screws to unscrew to view the tub. Is this a front loading one?Check the shock absorbers or springs & see they are in place. You hv to open it up or more damage will occur. Plug off the wall please.
Mar 16, 2007 | GE Profile Prodigy WPSE4200A
GE WBSR3140DW Top Load Washer Logo
41 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
