Question about Braun Activator 8595 Electric Shaver
Braun 8995 changing battery
Locating the screws to open
3 Suggested Answers
SOURCE: how do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Posted on May 25, 2009
kerguney
  • 577 Answers
SOURCE: resetting the how many shaves counter
Hi,unfortunately there is no way to reset this counter,even after replacing battery it still stands there.Braun somehow prohibits user and/or unauthorized repair men to do such action.If you visit the following link there is a official statement by Braun states that" total number of shaves (cannot be reset)."
I am sorry,this is the fact.
Regards
www.service.braun.com/line/SH/S5646/S5646_3_CHIN_KOR.pdf
Posted on Jun 05, 2010
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
I have a Braun Flex XP 5614. It´s some years now, and I have to charge almost every second day. I thought it would be smart to change the batteries, but how? I have removed the two screwes, but I...
You will find the correct batteries for model 5614 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
To open shaver, first remove the two round or oval screw covers on the bottom of the shaver. Then remove the screws underneath, The can then slide the outer case of the shaver down and off of the shaver inner body exposing the batteries
Nov 20, 2010 | Braun Flex XP 5614 Electric Shaver
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Sep 12, 2010 | Braun Health & Beauty
How to change the batteries
You can purchase the batteries for model 8995 at shaveroutlet.com. See link below. You will need two batteries
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver you will need to gently pry off the cap on the bottom. This is the piece of plastic that surrounds the hole for the charger. Once removed, the side grips will pull away revealing 4 screws. Remove screws and take off back cover. Then lift out circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs.
Reassemble in reverse order
May 25, 2010 | Braun 8995 Electric Shaver
Long hair trimmer wont push down
the switch/trimmer is broken inside and will need replaced. You will find the replacement item for model 8595 at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-8995-8595-and-8795-body-housing-with-trimmer-p-684.html
May 20, 2010 | Braun Activator 8595 Electric Shaver
The on/off slider is stuck on won't slide to off position
The trimmer/switch is broken. You will need to replace it. You will find the components that you require at shaveroutlet.com. See link below
To replace the part you will need to remove the 'cap' that surrounds the cord hole on the bottom of the shaver by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will easily pull off revealing 4 screws. Remove screws to seperate the front and back case. The inner parts simply lift out and you can put them into the new case
Mar 22, 2010 | Braun Activator 8595 Electric Shaver
How do I open the case to change the battery?
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Resetting the how many shaves counter
Regards
Aug 20, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun Activator 8595 Electric Shaver Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
