Question about Brother MFC-7820N Laser Printer
My machine is printing old infomation when recieveing a new fax
    Problem Solver:
  • 11 Answers
You need to do a factory reset (all) or try a memory clear of print data (partial).
Some one would have to walk you through it over the phone, or send it in to be done.should only be done by a service person.I cant post my email on here so not sure how to get in touch with you.
Posted on Feb 29, 2012
  • Doug Feb 29, 2012
    go here and follow it to enter maintenance modehttp://www.fixya.com/support/t272288-una...
    then enter 91 and then 99 to exit see if that fixes it.
    If not then go back into maintenance mode and enter 01 (this will clear everything) then 99 to exit
2 Suggested Answers
  • 3 Answers
SOURCE: New Ink Cartridge
Is the toner cartridge an original Brother or is it remanufactured? The toner cartridge for this model is the TN-350, which has a "flag gear" on the left (gear) side. It is a little plastic piece that sticks out on the new cartridges and, after putting the cartridge in for the first time, it rotates out of the way. This is how the printer knows that the cartridge is new. Some remanufacturers either don't put the flag gear in or they forget to turn it back to the original position when they build the cartridge. So that would be the first thing I would look at.
Posted on Jan 18, 2008
Hi we have a fax samsung sf-560r and recieveing fax and just going to memory and not printing..
press menu
#1943
menu again
look for new cartridge
it will print.
you can maby shack the cartrige befor you do this.
so that your prints can be better
May 18, 2011 | Samsung SF-560 Plain Paper Laser Fax
My fax machine cannon i sensys fax-l 120 is showing memory full. i cant recieve any fax. how i can clear memory
Hi
in order your fax to print you need to replace the cartridge
when the cartridge is low it stops printing incomming faxes
and keep it in mem untill you replace it with a new one
unfortunly this cartridge can not be refilled and use it
Hp is better on this
Jan 31, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
I have an old cannon fax machine from 1988. It has been blinking "recieved in mailbox" and I can't figure out how to clear it. the model is canon fax-705. can anyone help?
It has messages or faxes in memory, and is waiting for the right conditions to print.
You may need to add paper, replace the toner cartridge, or clear a paper jam so that the printer can work.
Mar 22, 2010 | Office Equipment & Supplies
AFTER REFILLING PAPER, MACHINE DOES NOT START RECEIVING FAXES IMMEDIATELY
It sounds like you have some bad jobs stuck inside the fax's memory. First print out a memory reference report. It will show you any bad jobs stuck in the system. Delete the memory reference jobs. Then go into set up and you want to turn off the option to store failed transmisions.
The system should store jobs while it is waiting for paper. If you have a lot of stored jobs and the memory is full it will not receive any more jobs until it can print out what is stored - so it would be normal for it not to recieve new jobs until all of the old jobs are printed.
Dec 24, 2009 | Canon FAXPHONE L80 Laser
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Brother MFC-7820N Laser Printer Logo
32 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
