Question about Goodman Heating & Cooling
Does not start main burner
Pilot goes ON but main burner can not start, and if it starts it goes Off in a few seconds.
  • Elena Feb 24, 2012
    I have Goodman two-stage multi-speed gas furnace.
  • dennis stone Nov 04, 2012
    where is flame switch
  • Goodman Master
  • 2,558 Answers
Faulty presure switch or flame sencor needs cleaning , check air filter is not blocked
Posted on Feb 25, 2012
Where is flame switch
Posted on Nov 04, 2012
eagle338
  • 4889 Answers
SOURCE: Pilot lights but main burner won't
There seems to be a problem with the inflow of gas into the burner..Check the connection for any blocks, loose contacts etc.,
Posted on Nov 01, 2007
  • 2558 Answers
SOURCE: main burner will not ignite Tempstar(NTC5075BFD1)
try cleaning the pilot oriffice it sounds like the flame is weak
Posted on Jan 17, 2009
  • 189 Answers
SOURCE: Pilot light goes on but won't ignite main burner?
What kind of heater? is it a gas furnace?
Posted on Mar 08, 2009
  • 139 Answers
SOURCE: Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Posted on Jun 21, 2009
  • 53 Answers
SOURCE: i have a vulcan freeloader 230 gas hot water
Clean the pilot assembly if has any orange at the tip. If its burning clean and blue, then its most likely the thermocouple. Safer to get a gasfitter to check it out.
Posted on Jul 18, 2009
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Pilot light keeps going out
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Heating & Cooling Logo
156 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
