Question about Samsung Cell Phones
My wall charger is not working anymore for my samsung conquer 4g what can I try?
  • 380 Answers
Download an application called "Advanced Task Killer". This will kill any unnecessary applications running which consume lot's of power on your phone. You can also try looking into your settings as to how everything else on your phone is running, which you may be able to change, which will also save power on your mobil device
-disable "Auto-sync" under "Accounts and sync" in settings.
-enable airplane mode or disable individual radios when not in use or in no signal areas like a basement (example: WiFi, 3g, 4g, GPS)
-If you disable "Automatic brightness" under Display settings you can control brightness by sliding your finger along the notification bar located at the top of the screen, Tip: the lower the brightness, the less power the display consumes.
-Use the built in task manager by pressing and holding down the HOME button and selecting "Taskmanager" from there press the "Help" tab to get more suggested tips To extend battery life.
Get power cords for work and home. If you use your car for travel during the day, like a salesman, get one for your car. All those other options are defeat the purpose of buying the phone. Airplane mode? Turn down the brightness? Disable auto sync? Huh? The reason we all got this phone is to USE THE PHONE AS IT WAS BUILT. The only way is to get more power cords. Swapping out the batter is requires removing of a case, if you have one. Pop the back. Reboot. How practical is that if you're using the GPS, on a call, or checking e-mail at the time the battery is about to die?
Cords. Cheaper. Faster. Simpler.
i think all the indulge heavy users should run extended battery...will avoid alot of stresssssssss...lol...
i used to go around ,loosing hours and hours tryn to find a piece of app to make it last longer,buyn,etc...no more...i mean i paid only 10 bucks with the cover at the metro store, even if is 16 like the post above,i think is still worth big time...that dosent mean u should ignore the phone problems and stop re-searching for a better way to make the phone better, but at least gives you more confor to do so,and less stress, use the litle ones for spare when u runing out of bettery and dont have much time to do a full charge etc...i have 2 extended and to standards...witch is no need once u have one extended is enough if dont use the phone alot, in case u do, a spare battery is suficient...the reason i got 4 is because i already had 2 standard before i got the 2 extended...once again,i think every indulge user should spend and extra few bucks and get a new extended battery...never buy used ones...
Posted on Feb 24, 2012
2 Suggested Answers
  • 77 Answers
SOURCE: my cellphone will no longer charge off of a wall charger
Hi there,,, are you with verzion? you can try a PRL update to get the new firmware,,, see if this fixes anything! To update your PRL, dial *228 and chose option 2
Posted on Jan 20, 2010
Sidekick battery not charging
That sounds to be a charger plug going bad (yes, the one from the device)
Try an electronics service to replace it for you .
Nov 17, 2017 | Samsung Cameras
Samsung conquer 4g says charging when not actually charging
Seems to be a software issue - try to do a factory reset or pull of the battery while the phone is operating (kind of a hard reset) and put back it an switch on.
Oct 29, 2012 | Samsung Conquer 4G
My samsung conquer won't boot up
Seen many Samsung phones behave this way. Try to remove battery for about a few minutes, then plug in charge without putting on. Let it charge for about 10 minutes then put it ON while on charge. I hope it will boot.
Sep 14, 2012 | Samsung Conquer 4G
How to splice samsung galaxy s cell phone car charger to wall charger
you should just do white to white and ref to red. just so you should know that ac chargers have a special crossover that the phone knows it is charging not usb' ing to a computer so you may get message on the phone to go into usb mode...just hot home and you well be fine
Apr 02, 2012 | Samsung Galaxy S 4G Cell Phone
How do you change the screen on a samsung conquer
Hi
Press menu.
Swipe side to side until you arrive to the wallpaper option.
Tap on wallpaper.
Select the desired wall paper option and tap on it.
Scroll the desired wall paper and tap on set wallpaper.
Good luck
Feb 23, 2012 | Samsung Cell Phones
My cellphone will no longer charge off of a wall charger
Jan 20, 2010 | Samsung SCH-u740 Cellular Phone
Logitech harmony does not charge
Mine does that on occasion. Is the blue light on in the charger base? If yes, check the connections on the charger base and the back of the remote to be certain they are clean. Does the remote do anything when you place it in the charger? If no to the blue light or the response of the remote, be certain the wall outlet is working, test the wall adapter, test the charger base. A voltmeter is handy for this. The only way to determine where your problem is, is to check to be certain all connections and pieces are doing their jobs. Test one at a time, divide and conquer. I hope this gives you some hints that lead you to a solution to your problem.
Nov 16, 2009 | Logitech Harmony 880 LCD Remote Control
Lost installation code for command & conquer
HKM5-YD73-72H6-B273-6FLT THERE YOU GO AND DONT FORGET TO RATE :)
Mar 22, 2009 | EA - Electronic Arts Command & Conquer 3:...
Cell Phones Logo
265 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
