Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
How many cubic feet are in GE frig model # TFH30PR?
Kenmore Elite Refrigerator 596.76253701 Looking inside the frig, I am unable to find the cubic feet fo this frig. Do you know what it is???
Should be a sticker on the back of the unit, most times they only state make and model number. You may have to enquire from Kenmore for cubic feet if it is not stated on the sticker.
May 27, 2015 | Kenmore Refrigerators
Model# FRT17B3JW6. need to know cubic ft. for selling
Normally the first two numbers in the model number are the cubic feet. You have posted 2 model numbers, on appears to be 21 cubic feet and the other is 17 cubic feet.
Jan 21, 2013 | Magic Chef CTF2125 Top Freezer...
How many cubic feet is my ge fridge, TFX25JP?
The first few numbers in the model number indicate the cubic footage...so that refrigerator is 25 cubic feet
GENE
Sep 08, 2011 | GE Refrigerators
253.64802409 (model), serial #BA60607122. Top freezer and I am haqving to defrost freezer every 3-7 days. The frig part of it goes up to 60 degrees. I would like to know how many cubic feet this frig is
Just measure the the inside of the fzr and frige and multiply length x width x hieght this will give you your cubic feet. (you will have to convert inches to feet) It sounds like your defrost timer, heating element in freezer, or the Hi temp sensor for the defrost cycle is bad more than likely the timer or element. good luck
Aug 10, 2010 | Refrigerators
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Refrigerators Logo
81 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
