-   Just this morning our Bunn coffee maker started to lead. I did notice a recall for the heating element (this one is new in '04). I am going to try to get it fixed under the recall, hopefully they will just send out a refurbished unit.-   mastanga1
If this is a home model, it will be leaking out of the plastic tray where you pour in the water. These trays get brittle over time and crack around where they mount into the top of the tank. If you are in your warranty period, call bunn warranty department at 1-800-263-2256 for assistance, and if not, you will have to either call your local Bunn repair shop to find a used tray, or purchase a new brewer, as Bunn does not ship parts for these models
Comments:
Feb 11, 2009
- If this is a home model, it will be leaking out of the plastic tray where you pour in the water. These trays get brittle over time and crack around where they mount into the top of the tank. If you are in your warranty period, call bunn warranty department at 1-800-263-2256 for assistance, and if not, you will have to either call your local Bunn repair shop to find a used tray, or purchase a new brewer, as Bunn does not ship parts for these models
dripping through weep hole in rear. took apart but see nothing wrong . not sure what model but has...
(More)
dripping through weep hole in rear. took apart but see nothing wrong . not sure what model but has stainless insulated pot
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot....
(More)
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot. Is there a gasket or part that has gone bad that needs to be replaced.
