Question about Apple iPod nano 3rd Generation
Hello sir i have tried the method what u told earlier but it does'nt work for me i have downloaded the firmware also
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me". Let's try do a re-format:
  • attach iPod to USB port of PC;
  • riight click on My Computer;
  • left mouse click on Manage / Storage / Disk Management / Action / Rescan disks;
  • follow on-screen instructions.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 28, 2008
Looking for MT661 window 7 driver
hi
Windows 7 is not available for this particular printer
these are the only OS's availafor the TallyGenicom MT661,
Windows 2000 - Code Version 5.2 or above
Windows 95/98 - Code Version 5.2 or above
Windows NT 4.0 - Code Version 5.2 or above
If the above drivers do not meet your needs, please try one of the following:
Driver
Description
Version
Windows 95 and 98
Driver - Firmware Version 5.2 or Later
3.51
Windows 95 and 98
Text Only Driver - Firmware Version 5.2 or Later
3.51
Windows 95 and 98
Driver - Firmware Version 5.1 or Earlier
3.01
Windows 95 and 98
Text Only Driver - Firmware Version 5.1 or Earlier
3.0
Windows 95 and 98
3.55
Windows 95 and 98
3.52
Windows 95 and 98
3.01
Windows 95 and 98
3.01
Windows 95 and 98
3.55
Windows 95 and 98
3.52
Windows 95 and 98
3.100
Windows NT 3.51
3.100
Windows 3.1/3.11
OS/2
Apr 13, 2011 | Tally MT661 Printer
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
Sir, I Have JXD 656 recently I connected it to my
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
  1. The most important step of the whole process is to correctly identify your device CONTROL CHIP and CPU, using wrong firmware or flashing tool may cause damage to your device, unscrew and open your device and write down all chip id's and motherboard numbers you see, you can also try the EasyChips - firmware identification utility but it did not worked for me.
  • You will now need to download the correct firmware and flashing utility for your device, visit sites below and search for your control chip and cpu to download the firmware and flashing utility, you can also post on user-forums to get help identifying the firmware :
  • In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
  • Once identified you need to connect your device to computer via USB in camera mode (Press A + OK button and plugin USB cord on player), for Windows to identify this mode you will need camera drivers you need to point Windows Found New Hardware Wizard to Driver folder downloaded with the FRM Pro utility above, this will install the first camera driver, for correct identification by flashing utility you need to install a second camera driver - open Windows Hardware Manager and install unidentified camera device drivers by pointing the driver wizard to Driver folder used earlier.
  • Now install and launch FSM Pro flashing utility the new firmware.
  • Jan 13, 2011 | Audio Players & Recorders
    The software on my sansa e260r is completely gone, when i start it up it reads" load main image failed, switch to recovery mode
    Firmware on the player can be reinstalled in 2 METHODS.
    In both methods the player should be in USB connection mode MSC = recovery mode.
    How to switch the player into MSC mode:
    0. Player not connected to a computer.
    1. When the e260R is not OFF, on the player press and hold the
    Power/Menu button for 15 seconds to turn the device completely off.
    2. Slide the Hold switch, so the orange portion shows.
    3. On your PC, double-click My Computer
    4. On your Sansa player, press and hold the REC button while connecting it to the PC.
    5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
    On a computer running Windows, you can use the Sansa Firmware Updater to get an automatic download of the firmware for the e260R.
    How to use the Sansa Firmware Updater [METHOD 1]:
    http://kb.sandisk.com/app/answers/detail/a_id/306
    If not installed yet, get the Sansa Firmware Updater to download:
    http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
    Right click the link above and Save target as... ; save the Installer to a location on your computer, install and run the updater on your computer. Select Firmware in the updater and Download Now, to start downloading the software for the player.
    When you prefer to download manually or if you have another operating system, the firmware can be downloaded from the forums site [METHOD 2]:
    http://forums.sandisk.com/sansa/board?board.id=e200R
    May 30, 2010 | SanDisk Sansa e260 MP3 Player
    Ipod suffle damage
    download latest quick time player
    Mar 08, 2009 | Apple iPod shuffle 3rd Generation MP3...
    IPhone not seeing DNS or Router on certain WiFi systems.
    fix =restore ispw 3G firmware that is earlier your present one, from someone like iclarified. try a few untill the wifi connects online.
    you can search net to see how to restore to earlier firmware using itunes.
    when wifi, hopefully works, update to latest firmware .
    I assume your phone is a import, australia, hong kong? not from your current country.
    even if it does nt work no harm should be done.
    good luck
    Dec 26, 2008 | Apple iPhone Smartphone
    Computer won't read mp3 player
    These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
    Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
    Download the Sansa Recovery Tool from the Sansa website.
    Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
    Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
    If these fail, then:
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
    You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
    -Tha Mp3 Doctor
    Sep 05, 2008 | Audio Players & Recorders
    Sandisk Sansa c200 displays "Memory full, free some memory" and doesn't function
    Player needs to be reformatted - checked my "tips and tricks" on Reformatting
    -Tha Mp3 Doctor
    May 27, 2008 | SanDisk Sansa c200 MP3 Player
    Web cam problem philips
    i do not have the setup of Philip spc 200 nc personal web camera. can you send it to me. help please.gona
    Dec 27, 2007 | Philips SPC 200NC Webcam
    Apple iPod nano 3rd Generation Logo
    22 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Parshiv Luthra
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
