Question about Naxa Electronics NX142 MP3 Player
Problems with naxa 4GB MP3
When i turn it on it says loading and that is all it does
  • 3 Answers
For some reason whenever I plug in my naxa 4gig as soon as it starts charging the sync arrow shows up... with nothing syncing. it's really starting to bother me as the battery can't fully charge because of it
Posted on Oct 26, 2012
2 Suggested Answers
  • 909 Answers
SOURCE: nx-142 my pc won't load the cd software or
www.mediamonkey.com
visit the above site and download/install the mediamonkey player. it will sort all your music and sync it to your player(you are given a choice of treating the player as a player or a hard disc drive) the just auto sync or manually sync......it's also an excellent alternative to windows media player.........and it's free
Posted on Feb 28, 2010
I purchased a defective HOM 220 GFI circuit breaker.What do I need to do to get a new one?
Install the breaker. Connect the neutral wire to the neutral bar. Do not connect any load wires to the breaker. Energize the panel and turn on the breaker. Check the output voltage of the breaker with a volt meter. If it reads correct your breaker is OK. Now shut it off and connect the neutral load wire to the breaker. Turn the breaker on. If it trips the problem is in the wiring or load. If not shut off and connect the load wires. turn it on, if it trips the problem is in the load wires or load ie motor.
Oct 05, 2017 | Electrical Supplies
Never done an update but phone keeps turning on and off not loading
This is called a loop virus. Same thing happened to my laptop due to internet use.
Nov 25, 2013 | Sony Ericsson P1i
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Circuit breaker keeps tripping when timer turns on. Also, if turned on manually.Intermatic T103. I've had this timer for about a year and everything was fine until now.
Since the timer doesn't trip the breaker until it turns on the load, the circuit is OK up to and including the timer. Either the load is faulty (has a short) or the wire supplying the load is damaged. You can test the wire that supplies the load by disconnecting the load then turning the manual switch to ON. If the breaker doesn't trip, then you know it is the load itself that is causing the problem.
Mar 21, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Problems with Loading into project
Install update 1.504 should fix the problem, i had to load it twice...
Jan 23, 2008 | Roland Vs2400CD Digital Workstation W/CD...
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Naxa Electronics NX142 MP3 Player Logo
272 people viewed this question
Top Naxa Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Naxa Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
