Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
The connection was reset The connection to the server was reset while the page was loading. The site could be temporarily unavailable or too busy. Try again in a few moments. If you are unable to load any pages, check your computer's network connection. If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
  • 2,260 Answers
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Posted on Feb 25, 2012
  • Heretyk Mar 11, 2012
    Not helpful at all. The problem is only happening when configuring the router to connect to it via HTTPS only. After changing from HTTP to HTTPS, the problem is reocurring. Leaving HTTP after reset 'solves' the issue, but I want to run it on HTTPS...Any ideas ?
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I own a linksys E1000 wireless router. After a storm & power blink-out, I could not access internet. Notice the 1,2,3,& 4 lights not lit. all other lights on right side were blinking. When I...
Normally on the back of the routers there is a small reset button you can press and hold for 15 seconds. This will reset the unit.
Click here for linksys tech support page. At the bottom there is a live chat option.
-G33k
Aug 09, 2011 | Cisco Linksys Wirelessn Router Black...
I use a Cisco Wireless-N Router E1000 to connect wirteless laptop. The Cisco is connected to the main router to internet. IP internet router is 192.168.1.254 The Cisco router is 192.168.1.1 The laptop...
I'm confident that having both routers distributing the same subnet is causing a conflict.
You should change the Cisco router to 192.168.2.1. and let it deliver IP addresses by DHCP.
That should do the trick.
May 13, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
New cisco Linksey E1000 router will only connect to local internet access, what do you I need to do?
Make sure to plug your broad band connection into the "internet" port or the yellow RJ45 jack on the back of the router. If that is already in place unplug all power connections to your Cable or DSL modem for at least 10 minuets. Then plug the modem back in and power up. Then reconnect your E1000 and wait for the unit to cycle. Then test for internet.
Also make sure to check any firewall software on the computers connection to the unit to make sure they allow or trust the new connection.
The last thing to try is to perform a factory reset on the E1000 and try the connection.
Mar 12, 2011 | Computers & Internet
Need to put a password into a router that has been reset
If you install the cisco connect software to your computer, you should un install it first to have a better access on the web UI of the E1000,
you also need to reset the router, access UI, 192.168.1.1(default IP)
go to the wireless tab and configure the wireless setting,
if you have any problem with it call 1-800-326-7114
Feb 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Trying to set up the E1000 using a motorola modem - insert disk, follow instruction, then it says you have successfully connected to the router, but you're not connected to the internet, and then windows...
You are getting the pop up asking for Internet access server drivers.
actually that is a bug in the Cisco connect server.
You can uninstall the cisco connect from that computer and reinstall the CD.
OR go to the device manager on that computer.
Under other devices you will find that internet access server with the yellow exclaimation mark.
Right click on it and disable it.
You can also setup E1000 router without CD or Cisco connect software.
Click here for more information
Jun 10, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
559 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
