Question about Samsung RS265LABP Side by Side Refrigerator
Cooling problem-set fridge to 34 will not go down past 50 took bottom off of rear of fridge vaccumed all of dust out unpluged for over 9 mins and pluged back in fan took a while to com on infront of compressor but it did come on and it droped from 59 to 57 but not going down any more I tryed the power freeze and the power cool nothing. the freeszer works fine but the fridge hasnt worked for about four days now please help it is only about four years old thank you
  • 517 Answers
Hello Sir Randy!!!
Welcome to fixya..
I remember that kind of symptoms happens before on my side by side ref..Try to check the coil on refrigerator side if it is iced up ..
Take this steps on how to:
  1. Open the refrigerator side.
  2. Remove the 11 screws on it..
  3. Get the hair drier..
  4. use the hair drier to slowly melt the iced behind the cover.
Note: If you pull too hard and or too soon you'll break the Styrofoam ducting that has to be around the coil. then make sure that the drain line is clear reassemble..
Hope it helps..Thank you for using fixya and choosing my service.
Posted on Feb 24, 2012
  • Rossiel Gomez Feb 25, 2012
    Thank you for the 5 star ratings sir I really appreciate it..
Will not get colder than 50
The first thing to check would be the condenser coils. Not sure where it is on your model, but when they collect dust, they do not allow the fridge to cool down correctly. It will be on the back of the fridge. Either running down from top to bottom or will be at the back behind the lower panel. If the condenser fan is running, then the coil is probably dirty. Unless someone has accidentally moved the temperature setting inside the fridge.
Feb 22, 2015 | U-Line 75R Refrigerator
Fridge not cooling
might need freon or the compressor going out cheaper to get a new or used one
Apr 22, 2012 | Maytag MFF2557KES 25 cu. ft. French Door...
NOT COOLING PROPERLY IN THE DOWN CHAMBER OF DOUBLE DOOR
remove bottom vent cover at front of fridge. just clips in place. look under neath and you should see a coil. its probaly caked with dust. use a shop vac or vaccum cleaner with small enough hose to insert under the fridge directly to the coil. remove all dust. dont use anythng sharp or pointed to clean coil, as coil can be punctured.
Jan 09, 2010 | Refrigerators
Fridge not cooling freezer works fine?
hi im andy from ac refrigeration in south africa ur fridge is short of gas
Jul 29, 2009 | Refrigerators
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool ET22DK NOT Cooling
Hi, Is the compressor running at all? Are the fans running? Whe you took the rear panel off in the freezer, was there any frost on it at all?
Vic
May 17, 2009 | Refrigerators
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Fridge not cooling down
The most likely cause is a gas leak . Call a technician.
Jan 22, 2008 | Refrigerators
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
Samsung RS265LABP Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
