LaCie hard drive is not recognized by Windows Vista
I recently upgraded my OS to Windows Vista Ultimate. Since then it has not been able to recognise my Lacie Hi Speed USB 2.0 Hard Disk. It says that the Hard Disk is compatible with Vista yet I cannot find a solution. Any help would be appreciated.
Cheers
Sam
  • 2 more comments
  • TPS07 Nov 01, 2008
    My drive was formated to Fat32 so that I could use it download video from my Sanyo HD cam. Lacie says that the drive should work as is, but I have the same problem.
  • Juan Vallejo
    Juan Vallejo Jan 14, 2009
    I am having the same problem. My External HDD is under FAT32 and I have Vista Home Premium (32bit) It seems to be installed correctly but I have no access, it is not shown under my HDD´s.... please some help!
  • Juan Vallejo
    I am having the same problem. My config:
    1 TB Lacie triple Interface - FAT32
    Windows PC Vista Home Premium
    I have tried installing it by firewire or USB... seems to be installed but not shown under my HDD...!!
    PLEASE HELP ME
  • JARiccio Apr 12, 2009
    I have a WD1001FALS 1tb hard drive that I move around from one computer to another. It is formatted FAT32 (on my MAC). Now, I move it to the VISTA Ultimate PC and it only shows up and "unallocated space".
    Can you run a FAT32 partitioned hard drive on Windows Vista? And if so, how??
    This is not running and OS, only backed up files.
    Many Thanks.
Well my hard drive is formatted in NTFS as this is how the instruction manual told me to. It's ok...i wasn't liking vista all that much so i rolled back to X. Cheers for the help anyway guys.
Posted on Nov 03, 2008
Thx for the reply. However, my the solution for me was easy; just plug the drive into another usb port. I guess the initial port I used was picky. My Vista 64 does recognize Fat 32.
Posted on Nov 02, 2008
    Problem Solver:
  • 4 Answers
Vista will not work in fat32 format
I packed my lacie big disk 1tb external on my way back from iraq and now my computer wont recognize it... What can i do???
welcome back home........was you using it on this computer overseas or a laptop.........is the OS the same (windows 98,xp,me,vista or 7) you might have to roll back or upgrade to
if you need to here is the link for update firmware
  • http://www.lacie.com/us/support/drivers/driver.htm?id=10053
Jul 08, 2010 | Computers & Internet
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Sata drive is not recognized by os during new install
When installing XP or Vista you get the option to load third party drivers for unknown devices. I think it's F6 just after the start of any version of Windows, once you press this you will have to supply the drivers for the Windows installation. This will make Windows recognise the hdd from then on.
Aug 18, 2009 | Gateway MT6821 Notebook
PC no longer recognises LaCie drive
Hi Katya!
There are several possible causes for this. You didn't specify if you're running Windows or Mac so I apologize in advance if some of the information I provide does not apply.
  1. If you recently performed a Windows Update, there's a patch to fix your issue; http://support.microsoft.com/kb/925196#fixit4me
  2. There is a firmware upgrade for your external hard drive. It is located here: http://www.lacie.com/ca/support/drivers/index.htm?id=10007
  3. If the above solutions don't solve your problem, you may try uninstalling the device and reinstalling it. This should clear any communications errors it may have
I do hope I was able to solve your issue. I wish you the best of luck.
Greg
Jun 12, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
It is not detecting the OS/partition on my HD
Take a look here: http://blog.atola.com/restoring-factory-hard-drive-capacity/
If that does not help please write your hdd model (Usually on a sticker on top of HDD)
What size is the partition the installation detects?
Jun 01, 2009 | Microsoft Windows Vista Ultimate Upgrade...
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
2,604 people viewed this question
David Payne
David Payne
