Question about DeLonghi DE500P Dehumidifier
Error Code 3
My unit stopped working and displays error code 3. I called Delonghi and they said I had a problem with one of the sensors. Delonghi will not tell me which sensor and will not sell me any parts. Do you know which sensor triggers error code 3? Can you suggest where I might be able to buy the new sensor? Thanks
  • 1 more comment
  • jasonwilliam Apr 20, 2008
    I have two DE500P models within the first year they both stopped pumping the water out. I addapted both to drain by themselves. Now I have a E3 message flashing on the display. I called Delonghi, and they said it was a sensor. Can I fix this unit or do I have to buy a more reliable unit such as a kenmore?
  • mpeaton Oct 13, 2008
    yes I have the same problem.
  • melndana Apr 20, 2009
    What needs to be done to correct E3?
I'm no expert appliance repair guy but this worked for me.
After systematically shorting out all the two wire sensors by disconnecting them from the controll/display panel I was left with the 4 wire connector going to the small circuit board wedged into the condensor.
I shorted out the black and yellow wires while this connector was disconnected, and plugged it in. You need some fine wire for this.
Plugged it in and the compressor and everything came on. Nothing on the display... unplugged it from the wall. Plugged the 4 wire sensor (maybe called the condensor sensor), plugged it back into power. E3 error gone, and the unit is working like a charm.
I looked at the small PCB on the condensor and only notice one ASIC and one capacitor. My guess is I drained the capacitor and it is happy.
Now all I need is the hose fitting to take advantage of the pump.
Good luck.
Posted on Aug 13, 2009
We www.ApplianceFactoryParts.com sell Delonghi Parts.  If you still need this please look on our web site.
Posted on Oct 10, 2007
    Scholar:
  • 104 Answers
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Posted on Mar 27, 2011
  • T Decker Mar 27, 2011
    opps forgot the "tip"...
    See ABOVE...
    Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
    Watch the LCD screen as it conducts a self test...and wha...lah!.
    Should have a working humidifier!
    (your welcome).
    no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
It may be that the error 3 is due to a pump malfunction. The pump malfunctioned on my 500p and when the pump float switch reservoir fills and the pump does not start the error code 3 indicates. You will also get a pump error light as well. I cannot find anywhere to purchase parts. Looks like purchasing a Delonghi was a big mistake. The unit didn't make it a year and a half.
Posted on May 22, 2007
  • 4 Answers
I have 2 of these units in service for about 2-1/2 yrs. They've been great except for having to clean the filter and lines about every 3-6 mos. The filter and exhaust panels along with the control panel side of the housing must be removed to get to it. I blow the lines out, clean the filter (soak first if necessary), then water tray. The design of the housing is terrible but the units have been very good to us. We use them daily.
Posted on Aug 07, 2008
DeLonghi DD70PE Dehumidifier. Why does pump often stop working and F/P shows an error code until reset?
id be inclined to think that for some reason the pump is taking too long to pump tank out (or it thinks it is ) this would cause the fault you describe and the safety control shuts pump off for fear of a problem
Aug 18, 2015 | DeLonghi Dehumidifiers
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
E3 code...what to do? on dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can provide you with the Error Code solution, as well as email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DH40P Dehumidifier
Error Code E-3
i don't know if this will help i have a delonghi portable ac and the e3 means not enough voltage to run properly. but it was doing the same thing as yours. i plugged it in where i knew there was good enough voltage and it works fine now
May 26, 2009 | DeLonghi DE500 Dehumidifier
Error code E3 on delonghi dehumidifier DH400P
(your welcome).
Apr 10, 2009 | DeLonghi DH40P Dehumidifier
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
Delonghi Dehumidifier E! error
I Had an E error (not an E1 error) when I was fiddling with my humidity/temp sensor on the face of the radiator fins (behind air filter).  The sensor was WET.  I dabbed it dry, let it sit all day, and re-assembled.  It works fine now.
Aug 30, 2007 | DeLonghi DE500 Dehumidifier
E3 is flashing on display panel
Calling two service centers, they both indicated that the main circuit board needed replacing. This would need shipping the unit!!, part and then labor. I figured over $120 - not reasonable. I then took the unit apart and followed the wires from the compressor to the back of the unit. This is where the moisture sensor was located - upper left. You'll see this when you take the filter off. Anyway, I cleaned the face of this part with a old toothbrush, used some compressed air to remove any dust. I then followed the wires with the black sleeve that went to what I think is a temperature sensor - also on the left. The wires go to a sensor that is pushed into a copper tube that is part of the cooling tubing. Gently pull this out, wipe it down and re-install. I then plugged the unit in, set the humidity level and it now works. I just put the unit back together and the compressor is turning on and collecting moisture! I will run it a few days and keep checking on it to make sure it doesn't go into the 'E3' Mode. By the way, the repair shops I called really didn't have a clue what the E3 code was. Dennis
Jun 15, 2006 | DeLonghi DDE40E Dehumidifier
DeLonghi DE500P Dehumidifier Logo
1,395 people viewed this question
Top DeLonghi Dehumidifiers Experts
Jim Goldsmith
Jim Goldsmith
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
