Question about HP Computers & Internet
Can't get new ink cartridges to click in - HP Computers & Internet
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    we will need the printer model number to help you..
    Scholar:
  • 195 Answers
Depending on your model of printer your ink cartridges has different ways of installing. Some just press straight in, and others you have to tip up slightly and press down. and of course you have to have the right cartridge. My printer for example uses two different black inks, one for pictures and one for print jobs, of course I can use either one for printing but they have different numbers. If someone helped you pick out your cartridge you might have gotten the wrong cartridge. Good Luck.
Posted on Oct 28, 2008
    New Friend:
  • 161 Answers
MY CRYSTAL BALL HAS STOPPED WORKING, GIVE US A CHANCE TO HELP YOU ??????????
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
    I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
    http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
    Replacing the ink cartridges B
    Your machine is equipped with an ink dot counter. The ink dot counter automatically
    monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
    Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
    a Open the ink cartridge cover. If one or more ink cartridges are empty,
    for example Black, the LCD shows Ink Empty Black and Replace Ink.
    b Pull the lock release lever down and take out the ink cartridge for the color
    shown on the LCD.
    C Open the new ink cartridge bag for the color shown on the LCD, and then take
    out the ink cartridge.
    d Remove the protective yellow cap (1). Each color has its own correct position.
    Insert the ink cartridge in the direction of the arrow on the label.
    f Lift each lock release lever and push it until it clicks, and then close the ink
    cartridge cover.
    G If you replaced an ink cartridge, the LCD
    may ask you to verify that it was a brand
    new one. (For example, Did You Change Blck?) For each
    new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
    counter for that color. If the ink cartridge you installed is not a brand new one, be
    sure to press 2 (No). If you wait until the LCD shows
    Note
    If the LCD shows No Cartridge after
    you install the ink cartridges, check that
    the ink cartridges are installed properly.
    Pls rate met. Thanks and Good Luck.....
    Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    Ink level didn't change
    s.gif Deskjet 5100 series
    1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
    2. Click Utilities .
    3. Click View ink levels .
      • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
      • If the cartridges contain a sufficient amount of ink, continue to the next step.
    4. Click Printer Maintenance .
    5. Click Clean Cartridges .
    6. Follow the on-screen instructions.
    ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
    May 29, 2009 | HP Photosmart D5160 InkJet Printer
    Cannot remove ink cartridge
    go to printer properties-- click the utility or maintainence tab-in that.click new cartridge installation process.and follow the instruction.its simple.
    Aug 15, 2008 | Epson Stylus CX3810 All-In-One InkJet...
    Epsom Sytlus DX4450
    Using the Ink Cartridge Replacement utility in Windows
    1. Open the Printers window by following the appropriate steps for your operating system.
    In Windows 2000: Click START > SETTINGS > PRINTERS.
    In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
    In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
    2. Right-click your printer model and select PRINTING PREFERENCES.
    3. Click the MAINTENANCE tab.
    4. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
    Caution:
    Never turn off the printer while the On light is flashing or you’ll waste ink. If the ink light flashes, press the Stop button and press down all the cartridges securely.
    Using the control panel
    1. Turn on the printer.
    2. Open the scanner and make sure its support locks in place.
    3. Press the STOP button. The print head moves to the ink mark to indicate which cartridge is low or expended.
    4. Press the STOP button again.
    If another cartridge is low or expended, it moves to the ink mark. Press the Stop button again to see if more cartridges are low or expended.
    If no other cartridges are low or expended, the print head moves to the replacement position on the right.
    5. Open the cartridge cover.
    6. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
    7. Before opening the new cartridge package, shake it four or five times.
    8. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
    9. Remove the yellow tape from the bottom of the cartridge.
    Caution:
    Do not remove any other labels or seals, or ink will leak.
    10. Insert the new cartridge into the holder and push it down until it clicks into place.
    11. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
    12. Release the scanner support and close the scanner.
    13. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Jun 05, 2008 | Epson Printer
    Computers & Internet Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
