Question about American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet
American standard cadet 3 leaking around seal
I installed the above about 1 year ago. Shortly after installation, the toilet would start to refill about 1-2 times an hour. I took the top off and you could see and hear it leaking slightly thus why the refill. The setup is unique and simple but I have tried everything from adjusting the way the seal is seated to replacing the seal/rubber gasket. Sometimes when you flush the seal doesn't seat properly and the toilet leaks constantly and refills every 5 minutes. I either flush toilet again or adjust the seal and the problem seems to go away until the next flush.
Any thoughts?
  • aagagease Apr 10, 2009
    I have the same problem with a new American Standard Cadet 3 toilet after about 6 months. I see on my rubber washer on the flapper that there are bubbles (within the rubber). I tried flipping the washer the other way temporarily (by unscrewing the cap on the underside of the flapper) until I can get a new washer or flapper assembly, and while this resolves the bubbles that made for an uneven surface the toilet does still leak at the flush valve. So I'll still try replacing the flapper and washer, but I am wondering if there is a flaw with the design somehow.
  • tito Jun 09, 2013
    leaky problem in my american standard cadet toilet in the top of water shutt off assembly
There is none. I thought I had an unusual case but after replace numerous flappers (some purchased and some sent by AS, this toilet will continue to leak into the bowl. American Standard sent a new complete flush valve and that did not work. This toilet has leaked for 4 years now and I have to shut the water off manually. Good flush, bad design for water retention. Contacting AS two weeks ago asking for a replacement tank has met with stall while they review. I'm done waiting. Two Kohlers in the house do not leak a drip. Guess what happens today? If I do not have contact back today I'm going to the local home center and buying a Kohler, and will be a stuanch critic of AS fixtures in that aisle from this day forward. They know anout this but can not fix it. Cram that five year warranty. Like the line in the movie said, "Guaranteed, I can sh** in the box and mark it guaranteed, and you would have a guaranteed piece of sh**.
Posted on Nov 13, 2010
  • schmidttim Nov 12, 2013
    Three years to date with the Kohler and I have never heard it cycle between flushes. I.e., no drip or leak. Screw American Standard!
  • Anonymous Nov 07, 2016
    I started having exactly this problem after a year in the American Standard cadet 3. They sent me new flappers, slow leak still there. I had gotten Koehler for my other toilet same time, which rocks till date with no leak. I plan to replace this Cadet 3 with Kohler. After 15 years I replaced original Kohler to water efficient toilet. I tried new Kohler in one toilet and the American standard in the other. The results are clear, American Standard is dreadful in quality. also the customer support was arrogant. Will never buy AS again.
    Genius:
  • 1,605 Answers
Get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Posted on Nov 07, 2008
    New Friend:
I have the same problem with my Cadet 3, which started about 6 years after Purchase. I tried replacing the flapper and it still leaks. Then I found out it is NOT the flapper. I turned off the water supply and after 10 hours all the water drained out of the tank, and that includes water BELOW the flapper valve seat. I have seen several places it is the tank to bowl seal, and possibly a rough surface on the porcelain where they join which needs to be sanded before replacing the seal. Since mine developed late I suspect it is partly due to the bleach in our water system compromising the valve seat where it meets the tank bottom. We treat our spring fed household water tank by hand, and the bleach concentration varies with water inflow and outflow. (We are now cutting back on the bleach.) Before I pull apart the toilet to install a new gasket, I will try two things: 1) tighten the bolts holding the tank down. If that doesn't work 2) I will pack some plumber's putty around the the base of the valve seat where it meets the tank bottom. I will report back with the results.
Edit: The directions that came with the toilet said not to use plumbers putty. I fixed it with a generic Fluid Master Flush 3" Toilet Flush Valve Kit, which comes with overflow tube and valve, tank to bowl seal, and tank coupler seal and hardware. At around $15 at Home Depot it is only a $1 more than the American Standard coupler kit (and it is in stock, the AS kit has to be ordered). The Fluid Master kit has independent seals for the tank connecting bolts, which makes it a better configuration than the original. It is sealed with two gaskets and bolts which are tightened to the bottom of the tank (instead of just one nut per bolt at the bottom of the bowl). The same bolts then extend and attach to the bowl with a second nut. This independent seal means that the tank can be removed without breaking these seals. The only drawback is getting the bolts properly aligned for the bowl attachment since there is no bushing to center the bolts in the tank holes as in the original. I recommend either using the original bushings (cut them off the seal) or rubber tubing for this bolt alignment.
Posted on Apr 07, 2017
    New Friend:
I had the same problem with my AS Hamilton one piece. I replaced the flapper but the problem still existed where the unit kept on refilling every now and again. Checked with American Standard only to be told that they do not carry the parts and we would have to replace the whole flush system with a generic model with an internal expander which makes the seal. I decided to use a Master Plumber tank to bowl seal #233 and it works just fine. This cost was $3 versus $45 for some generic fix. All you need is a socket wrench of the correct size. Just remove the flapper and float arm for easy access. Don't over tighten the new washer as it may crack the internal bowl flange.
Posted on Jan 07, 2016
    New Friend:
  • 36 Answers
Re: Replace flush valve seal
The American Standard Cadet 3 flowise one piece toilet uses a flapper valve with a soft nylon washer to seal against the water outlet.
Over time this nylon washer develops 'puckers' causing water to seep between the nylon washer and the seat of the flapper. This seepage causes the water level in the tank to drop to a point where the water inlet valve opens to replace the lost water in the tank.
There are two ways to correct this problem:
1. Replace the soft nylon washer on the flapper, or
2. Replace the entire flapper valve.
Hope this solution helps.
Posted on Sep 02, 2015
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
Leaking at base after flushing
are you sure its the floor connection as it could be the tank one, also if the floor section is there a insert sealed and fitted to the existing floor pipe and then the wax seal around this. similar model video. https://youtu.be/LebANJC2rx4
Jan 11, 2018 | American Standard Cadet 3 Right Height...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
I have a american standard cadet 111 6liter elongated toilet. I have replaced the flaper and the rubber seal in tank and I still have a problem with the toilet refilling itself after a hour or so. Any...
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
Feb 22, 2011 | American Standard Cadet 3 Right Height...
Slow leak from tank into bowl. We can hear tank refilling once or twice a night.
I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped. Edit your post: insert-link-blue._v192249896_.gif To insert a product link use the format: [[ASIN:ASIN product-title]] (What's this?) I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped. cancel-glossy._v192250345_.gif deletepost-glossy._v192250344_.gif Guidelines
Feb 04, 2011 | American Standard Cadet 3 Right Height...
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | American Standard Home
American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet  Logo
5,691 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
