Question about Makita Gd0600 Die Grinder
My GD0600 quit suddently while I was grinding out a hole; no reason why, it just quit suddently??
Brand New, very little use GD0600 Makita Die Grinder suddently quit while I was grinding out a hole in 1/2" metal. No strain nor bind on the bit nor motor; it just quit with no reason. Thanks.
2 Suggested Answers
  • 2468 Answers
SOURCE: plug in makita die grinder, turn on, runs for 2 to
does it run freely?as in not seem to be lugging from bad bearings in the motor shaft,then check the speed control board for a shorted triac/scr transistor
Posted on Mar 25, 2011
How to fix a die grinder
a more Discriptive question is needed.
Apr 09, 2013 | Makita 14" Die Grinder
How do you reset a makita gd0600 die grinder?
How much wear has it had. The carbon brushes could have worn out and need replacing.
Jan 28, 2012 | Makita Gd0600 Die Grinder
My makita grinder was working just fine wile I was grinding it just quit on me and now it will not even start
You can try removing brush covers and brushes to check and clean as needed.I have a makita grinder and have to change brushes about every two years but I use mine a lot in very dusty conditions.I think that I would probably check on/off switch about first as I have had mine do exactly what you have and I replaced the switch and it's still working.I have had mine for 15 years.Great little grinders. If you feel comfortable doing so you can bypass swith to make sure motor is good. Best of luck and thank you.
Apr 17, 2011 | Makita Angle Grinder 4.5" 9524NBX
Plug in makita die grinder, turn on, runs for 2 to 3 seconds and pops breaker. It is a variable speed grinder
Mar 25, 2011 | Makita 14" Die Grinder
Want to put in new 1/4" collet cone.......how
Undo the collet nut then find something that you can get a firm grip on the old collet and pull it out. If this doesn't work and it is still stuck carefully try an eze- out to remove the old collet. Once you have removed the old collet just insert the new one and replace the nut.
Feb 11, 2011 | Makita GD0600 1/4 Inch Die Grinder With...
I have a Makita 100mm Disc grinder what attachments are available for this older tool...model M952
as its a grinder...there are not many attachments available....just your common grinding and cutting discs.
Aug 06, 2010 | Makita 9553NB 4" Angle Grinder
My Makita bench grinder has four holes to change the grinding wheel..how to I get the retaining nut off as I don't have a tool to fit the four holes?
Make your own wrench out of a piece of wood stock,with 2 screws or nails spaced out to 2 opposing holes in the retaining ring/nut.HarborFreight sells a 'spanning wrench' online .
Jun 30, 2010 | Makita Nip 5"(127mm) Bench Grinder Wheel...
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Loud noise coming from above paddle switch. Sounds like a baseball card in a spoke almost.
Could be quite a few things from something in the fan to a coupler that is splitting apart. I would recommend going to Makitatools.com and typing in your model number and downloading a breakdown if you are going to fix this yourself. Let me know if I can help, it has been awhile since I worked on one of these.
Feb 22, 2009 | Makita Gd0600 Die Grinder
Makita Gd0600 Die Grinder Logo
97 people viewed this question
Top Makita Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Makita Grinder Expert? Answer questions, earn points and help others
