2002 Mercury Mountaineer Logo
Anonymous Posted on Feb 24, 2012
2005 Mountaineer--Oct. power windows and radio quit working. soon after check engine light came on. brought to dealership. they said it was fuel pump(?0 and fuse. Didn't agree but 1000 dollar
  • Anonymous Mar 02, 2012
    I think the problem is solved. My lighted visor was broken and some of tiny wires were exposed. I think this was causing the fuse to blow. It's been five day since I disconnected the visor, taped the wires, and replaced the fuse and it hasn't blown yet.
Reynaldo Andico
Level 3:
  • Mercury Master 2,431 Answers
  • Posted on Mar 02, 2012
Reynaldo Andico
Mercury Master
Level 3:
Answers
2431
Questions
0
Helped
1235203
Points
7940
That was the problem this is called a logic box the visor is connected fuse that control window and radio,
2answers
I have a 2005 Mercury Mountaineer and the overdrive and the check engine light comes on with the check transmission. What could cause that, what do I do?
Question edited for clarity.
Question moved to model category.
The check engine light alerts you that you have a problem that needs attention and then you connect a code reader scan tool and it gives you numbers. Those number tell the problem and how to fix. They are called DTCs (Diagnostic Trouble Codes). Garages will normally read the codes for you for free in the hope of getting the work. Or you can get a cheap code reader yourself.
I have the FIXD scanner which sends the information to an app on my smartphone.
https://www.google.com/search?q=fixd+scanner&
DTC Codes
https://www.google.com/search?q=2005+Mercury+Mountaineer+DTC+codes
2003 Mercury Mountaineer. Why did my power window and audio quit at same time on my car?
Fuses?
Fuse box location and diagrams: Mercury Mountaineer (2002 ...
YouTube https://www.youtube.com > watch
2:55 See more on our website: https://fuse-box.info/mercury/mercury-mountaineer-2002-2005-fuses-and-relaysFuse box diagram (location and ...
YouTube · Fuse Box Info · Dec 30, 2018
Mercury Mountaineer (2002-2005) fuses and relays
Fuse-Box.info https://fuse-box.info > mercury > mercury-mountainee...
The fuse box is located under the instrument panel on the driver's side. The location of the fuses in the passenger compartment: Mercury Mountaineer (2002-2005 ...
Dashboard lights and headlights and radio and power windows quit wrk
cud be a bad fuse--there are some in engine area too--may hav to test each one----a flaw in the wiring also--or a module that controls the diffrent functions------aquire a service manual or a private shop is best direction
2003 chevy mailbu - 3100 SFI engine
Thats pretty wild. The a/c and power windows are on different circuits.
The only thing I can think of that everything would be connected to is the ignition switch.
2005 mercury mountaineer power window will ot let down, radion will not play and fuel gauge not working. This all went out the same time what is this?
Initially look at the fuses. The windows will have their own fuse and the radio may work on the same fuse as the gauges. The fuses must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown ones. A small pair of pliers will ease removal of the fuses.
1helpful
Radio windows and fuel read out stopped working
Check Fuse 2.3 (20 Amp). See electrical diagram below.
When it goes, it'll take out the audio and "Cluster and Panel Illumination."
(assuming your vehicle doesn't have an OEM Nav system - in which case fuse 2.3 would
supply power to the Nav system).
Fuse 2.3 is located in the CJB (Central Junction Box) - not the BJB (Battery Junction Box),
nor the AJB (Auxiliary Junction Box).
Also, check fuses F1.6 (60 Amp), and fuse F1.62 (30 Amp) in BJB (Battery Junction Box).
Also, check fuse F2.17 (15 Amp) and the "Accessory Delay Relay," both in the CJB (Central
Junction Box).
Here's the electrical diagram for 2005 Mercury Mountaineer Power Windows:
Note how fuses F1.6, F1.62, F2.17, and 'Accessory Delay Relay" will all
disable the power windows.
Windows and Radio quit working in Mercury Mountaineer 2002
the first thing to do is go to your fuse box to see if there are blown fuses i won't comment on your statement however hope this helps regards Jim
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
