Question about Philips Magnavox 42MF521D/37 Television
I have a philips 42" plasma t.v.model
    Sergeant:
  • 195 Answers
Hello sir Dave!!!
welcome to fixya..
Lets find out if that problem is worth to repair or not..I need some info regarding your TV such as how many flash of LED lights in front?..It will help to diagnose where the fault came from..
Please reply to this tread to post the info I need..
Thanks for using fixya..
regards,
Chester
Posted on Feb 24, 2012
  • dave webb Feb 24, 2012
    in,reply yo your question,when I plug tv in I get a green light,when I turn on the tv I get a red light that flashes 7 times.
  • chester pendilton
    chester pendilton Feb 25, 2012
    OK sir I already encounter that kind of problem before..
    just follow this steps:
    1. Open the back cover.
    2. Power ON TV and look at the green lights on power supply.If the green light flashes 3 times vscan voltage error.
    3. Unplug the Y sustain and read the voltage on vscan it should have 190vdc.
    4. If the above procedure correct the Y-sustain fault but in all plasma TV when the y sustain fault also the upper and lower buffer got fault too..
    5. Replace y sustain and lower/upper buffer then try to power it ON to test if OK..
    Hope it helps...
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
Plug in green light comes on after a few second red light
replace power supply module part number,LJ44-00101C
shopjimmy.com has it in stock
Sep 29, 2009 | Philips 42PF7220A 42 in. Plasma Television
RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a philips 42pf7220a/37. when i turn it on the picture is fuzzy and red.
Any luck with fixing your Model#42PF9630A/37 as I am having the same problem with mine?
Thanks
Feb 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips Magnavox 42MF521D/37 Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
