Question about Meiko FV 40.2 Dishwasher
Error Message coming up
I have a Meiko dishwasher that has been running fine for some time now. Just recently, though, an error message would pop up and the machine would stop running. The error message reads as follows: "ERR203". I need to find out what this means and fix it A.S.A.P. If there is anything you can do to help... please.
    Problem Solver:
  • 11 Answers
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Posted on Feb 05, 2007
  • colin smith
    colin smith May 13, 2008
    203 No change detected by the level switch
    when draining
    S2
    Booster pump defective
    Booster pump plug connector loose
    Start capacitor defective
    Plug connector loose
    Boiler level switch defective
    No boost pump signal to – from I/O
    PCB
    No “boiler full” signal from I/O PCB
    Check booster pump / S2 with manual
    control
Err110 on kv200
Posted on Sep 13, 2010
  • 70 Answers
1)booster pump defective.(check the connector loose)
2)start capacitor defective.
3)boiler level switch defect.(water not entering in to the machine)
Posted on Jan 09, 2010
Faulty final rinse water quantity
Posted on Feb 10, 2008
THIS GUY HAS NO IDEA WHAT HE IS ON ABOUT
Posted on Feb 05, 2008
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
What is 110 maintenance need meiko dishwasher offenburg d-77652
what is 110 error codes maintenance need meiko dishwasher
B230vap
May 23, 2014 | Meiko Dishwashers
Meiko dv80.2 message: info 124 we don't know what
you have opned the hood close the hood the error will disapear
Jun 13, 2011 | Meiko DV 80.2 Dishwasher
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
May 26, 2011 | Meiko FV 40.2 Dishwasher
Error 111 meiko dr80.2
it's water leakage inside the machine(or)water leakage switch defective.
Jun 20, 2009 | Meiko DV 80.2 Dishwasher
Alps MD 5000
When you moved, did you secure the print head and remove the ink cartrdiges? A Changer Error message is bad. Check the changer for any broken or bent parts.
Sep 06, 2008 | Alps MD 1000 Thermal Printer
Cubase 4 Error Message
Same problem with audioprimitive.opt on Cubase 4
Mar 21, 2008 | Audio Players & Recorders
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Error Message E4 54037380
call manufactor and see if your serial number qualifies for a firmware upgrade.
Dec 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Dishwashers Logo
2,066 people viewed this question
Top Meiko Dishwashers Experts
Tom Chichester
Marvin
Marvin
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
