Question about Brother Office Equipment & Supplies
Reset purge counter on Brother MFC-845 cw. What next?
I have a Brother MFC-845 cw all in one printer. I've always had a difficulty in that the IP address moves around. In order to print I have to check the Network Configure report settings. For main documents it still prints ok. However when it comes to printing the Network configure report, it's unreadable, so I can't change the setting on my computer and print out. I did once try to install an update which was supposed to solve it but it didn't. When I do a print test, the yellow is invisible, the black has many blocks missing, the blue and magenta is okish. I have used up many ink cartridges cleaning. Finally I got an error 46 message but managed to reset the purge counter. However the network configure report is still illegible. Is this something to do with the ink blocking, and, if so, can anyone give me an idiot's step by step guide as to how to unblock it? I need it simple and clear, if it can be done and it is possible to fix it. The machine is otherwise in good condition. Thank you so much!
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
My Brother Printer (MFC 490 cw) (LC61 series) has an "Unable to Init. 4F" error message and won't do anything. I've tried some options to fix I found online but hitting buttons just gi
Hello there,
When in doubt..... ALWAYS read the instructions
Well the user guide for this machine (which you should already have) talks all about 'unable to init xx' on pages 139 and 140.
Have you trd following the instructions exactly ?
Download here http://download.brother.com/welcome/doc002373/mfc490w_usaeng_usr_b.pdf
If it still has a problen get in touch with Brother support.
http://www.brother-usa.com/support/default.aspx
Sep 22, 2014 | Brother MFC 490cw Color Inkjet...
How To Reset Purge Counter on a brother mfc-j4710dw
Mar 03, 2014 | Brother MFC-J4710dw Color Inkjet...
How do I remove and replace the ink absorber pad/tank on my Brother MFC - 820 CW
Have a look at http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c which is specificlly for the MFC-210c - no sure how similar the 820CW is.
It's in German but google does a reasonable translation.
After receiving a "UNABLE TO CLEAN" message, I've just cleaned the pads on my MFC-425CN (washed in cold water) and re-set the purge counter - all working fine now.
John D. - Adelaide
Nov 17, 2012 | Brother MFC 210C All-In-One InkJet Printer
Clean unable 5A error message Brother MFC-290... Plz Help me.
Hello, the error message your printer display is as a result of your printer's purge until it had reached it counter limit and you have to reset the printer by leaving it unplugged for at least 2 hours and then boot it back up. this will flash the memory of the machine.
Thanks
Jul 04, 2011 | Brother MFC-290C Printer
Brother 8890DW Wireless Configuration Difficulties. I want to configure the above printer through a wireless acess point connected to a router via ethernet. The router sees the printer, yet the computers...
I don't have a solution, but I have a similar problem with a new Brother 8690DW MFC machine. Out of the box - I can't establish wireless connection. Brother "tech support" (!) insists I am typing in the WEP key incorrectly... doesn't matter to them that I've configured literally hundreds of devices with encryption keys before.
I'm about ready to return this machine and get another. Yet, I suspect that the Brother setup instructions are missing something I need to do - I can't figure out what, though, and have been through every relevant setting I can find.
Apr 13, 2011 | Brother MFC8440 Remanufactured Laser...
I reset the purge counter on the brother printer MFC210C now error A7 appears, don't know what to do now.
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother MFC 210C All-In-One InkJet Printer
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
