Question about Toshiba 27A34 27" TV
How to eliminate white lines at top of tv - Toshiba 27A34 27" TV
Sorry fellow fixya user you cant its what happens when a tv is old or pad quality it cant be fixed the same thing happened to mine and thats what the repair man told me.
~GURTRUDE~
Posted on Feb 24, 2012
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
May 10, 2014 | Proscan Televison & Video
How to eliminate black/white lines on the screen ?
The video output section to your TV is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there
Nov 05, 2012 | Televison & Video
My tv goes on and works then the picture disapears and the tv shuts down with the lamp lamp/heat and source blinkers on. what does that mean?
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Mar 30, 2011 | Samsung HL-S5087W DLP TV
My samsung dlp turns on, then after 10-15 sec turns back off
Mar 04, 2011 | Samsung HL-S5087W DLP TV
10 fine white lines at top of tv screen
replace capacitor at vertical section
May 26, 2010 | Panasonic CT-27G14 27" TV
White Horizontal Lines @ the top of my 32" Sharp Black Box TV
This Problem is usually caused by Leaky Capacitors in Vertical deflection circuit.
If you are handy with electronics,
Get a can of FREEZE Aerosol.
Open the Back Cover.
Put a mirror in front of TV.
Locate the Vertical Circuit.
Turn the TV on.
Spray FREEZE on top of individual Capacitor to see if it corrects the problem.
If it does, Replace that Capacitor.
Feb 06, 2009 | Sharp 32C-240 32" TV
RCA tru flat 27 tv problem
the capacitor of vertical section is problem of your tv,so replace the capacitor value 100/50volts in or else all capacitors in vertical section.
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
Horizontal lines on top fourth of picture
the guy who sold it to you has the same white lines on his forehead.emagine that. wallmart is real cheap.
Jan 04, 2008 | Sanyo DS32920 32" TV
Toshiba 27" standard def. TV
white narrow lines mean at the top of the screen called top retrace lines it is due to vertival section. any high value elec. cap might be defective.
Sep 13, 2007 | Toshiba 27A34 27" TV
Toshiba 27A34 27" TV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
