Question about Hauck Baby Gear
How to fit carrycot to a hauck turbo trio plus pram
Hauck turbo plus carrycot system, how do you assemble to frame?
SOURCE: chicco trio
on the top rim of the carrycot, hidden by the hood, there is a button each side, press these at the same time to release the carrycot. It should then lift off.
Posted on Jul 19, 2008
SOURCE: Phill and Ted pram hood hard to put back in place
I have the same problem with a Phil and Ted's Sport - but I believe I have the solution as below. This is taken straight from the Instruction Manual which you can view at: http://www.arango-design.com/Phil-Teds-Sport-Buggy-p/7890-0001.htm - towards bottom of page is a link to the instruction manual - which I was unable to get on the Phil and Teds website. Got this today but haven't tried it yet. Hope this helps.
Really becomes clear when you see the pictures in the instruction manual.
Regards, John
Hood
The sport hood is packed disconnected.
To reconnect:
1. Locate sun hood and hold it facing down, as shown ‘a’.
2. Insert crimped wire ends into frame, through eyelets, ‘b’.
3. Lay hood back (to top of buggy).
4. Locate red coloured pocket at top of fabric seat and insert rear hood wires into each side, ‘c’ and ‘d’.
5.Open hood and attach domes, at bottom of hood, to main seat, ‘e’.
6. Pull eyelet at top of hood over pegs on each side of frame, ‘f’
Note that the windows in the hood are lined with a sun mesh of
a lower shade factor than buggy fabric. Always use sun cream
and clothing for protection of children in direct sunlight.
Posted on Jan 29, 2009
  • 11 Answers
SOURCE: Can i put a bugaboo frog carrycot on a gecko
I WOULD TRY A CAMELEON CARRYCOT FABRIC, THIS IS SLIGHTLY LARGER THAN THE FROG AND MAY GIVE THE LEE WAY THAT YOU NEED :)
Posted on Jul 14, 2009
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
Posted on Sep 06, 2009
  • 419 Answers
SOURCE: how do you fit the ventura plus car seat onto the
This is a little difficult to explain in text, but here goes..
Recline the seat unit to it's lowest position.
On the arm rests of the pram, there is a piece of fabric covering each arm, these are attached via press studs, undo these and fold them backwards onto the seat area.
This will reveal a plastic hook underneath, these are folded down and need to be raised upwards.
Next, get the Ventura carseat and ensure that the handle is in the carrying postition (i.e facing upwards). On the base of the carseat at the back (directly underneath babys head) there is a distinct cut out shape that will fit snugly onto the bumper bar of the pram, place the carseat on top of the pram (so it is positioned on the seat facing you) and push it down gently. If this is the first time that you have done this, the material may be quite plumped up so you may need to push a little harder.
At the base of the carseat handle either side, there is a button (this is used to adjust the handle position) push these buttons down at the same time and move the handle backwards (away from you) until the handle makes an audible 'click', this means that this has now secured onto the plastic hooks that you first exposed on the arms of the pram.
This should now be securely fastened onto the pram.
I would also suggest that you visit this website as per the link below and download the user manual for the 3D so that you have this is picture format in front of you.
http://www.silvercross.co.uk/contact/instruction-manuals/
I hope this helps.
Posted on Sep 23, 2009
Mountain Buggy Duo Carrycot Installation
Hi
We would recommend you make contact with Mountain Buggy via their Contact Us enquiry
Welcome to Mountain Buggy Mountain Buggy
Jul 13, 2014 | Mountain Buggy Duo Black Standard...
I hav a hauck winnie the pooh 3 wheeler pram need a hood where do i get one from plz
Try here. http://www.hauck.de/en/service/service-contact.html
Dec 26, 2012 | Baby Gear
Which adaptor will fit a quinny buzz pram and a maxi cosi cabriofix?
You can purchase Quinny Buzz adaptors via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 10GBP a pair plus 3.99GBP p+p if ordered direct. These adaptors will fit a Maxi Cosi CabrioFix, a Maxi Cosi Pebble, or a Quinny Folding Carrycot to the Quinny Buzz chassis.
Nov 24, 2011 | Quinny Baby Gear
Should the bugaboo carrycot have wires that do in the long pockets at the front and back of the carrycot pram?
Yes, athough these are not really wires, these are more like rods. There should be two (one for each end) and they will be black and about an inch wide and nine inches long. These rods will make the carrycot rigid when assembled.
Hope this helps.
Sep 26, 2010 | Bugaboo Cameleon Stroller
Hauck Infinity Spare parts
Hi
Try mother care shops
thanks
May 05, 2010 | Hauck Infinity Stroller
Bebe confort compatibility old carrycot etc with a new chassis?
i don't know about the seat unit or car seat but i've got a prelude carrycot and it fits on my loola, hope that helps
Amy
Jan 18, 2010 | Baby Gear
Unable to assembly carrycot on to stand on my bebecar 3in1 pram
The carrycot attaches in the same method as the seat unit. You place the clips on the base of the carrycot in the four runners on the chassis. You can obtain instructions by emailing service@bebecar.co.uk
Nov 17, 2009 | Bebecar M City Stroller
Spare parts for Hauck Infinity?
i need the foam that goes on the handle of the pram and cant seem to find it anywhere can you help
Nov 05, 2009 | Hauck Infinity Stroller
Have you managed to fit the carrycot already
If this is the same as the UK model then you should make sure that you remove the hood of the pram (not the carrycot hood) as this makes life so much easier. You could contact www.mountainbuggy.com so that they can send you a manual.
When you attach the carrycot, there should be a clip either side of this to attach to the chassis, these clips snap shut when aligned correctly with the chassis.
I hope this helps.
Sep 14, 2009 | Mountain Buggy Urban Single Stroller
Baby Gear Logo
Top Hauck Baby Gear Experts
Kelley Hopper
ray gallant
Dorel UK
Dorel UK
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
