I can't even get onto the computer it is locked
Hi charla vetter, to gain access, and change your "Password."
Follow these instruction:
Restart the computer; and at the moment of start-up, you want to 'press' the [F8] button before the (login screen) appear!
Keep press the [F8] button until you see the "Recovery Options" screen.
Now, scroll by using the [Arrow -> <- buttons], and select the "Safe Mode" from the list.
This will (Boot the computer into Windows, without logging in).
Your computer will start-up, and you will not have to "Login."
Next, you want to go to your "User's Account" to change your password.
To do so, click on the "Start button -> Control Panel -> User's Account,"
or you can Type: "user" in the Search box.
Next, change your password, and press the Apply and OK buttons.
Now, after you restart the computer, you can log-in with your new password, and you can also add a {Hint}, as a reminder!
I hope all goes well !
"best regards, paul7of9"
SOURCE: Forgot password to log on to notebook
Start up from a Mac OS X Install CD (one whose version is closest the the version of Mac OS X installed). You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
Important: Do not select "System Administrator (root)". This is actually a reference to the root user. Do not confuse it with a normal administrator account.
SOURCE: Password Lost
press ctrl alt del twice all together then type administrator in username press enter. may work other wise pls check back
SOURCE: FORGOT PASSWORD AND CANT LOG IN
Did you make a password reset disk? 2ndly did you remember the administrator password when you setup the computer?
SOURCE: Forgot BIOS Password Latitude D820
hi,
first take out the main batteries then
you can try to unplug the little clock battey in the memory comartment and push and hold the power button while its out. plug it back in and try it.
good luck
J
SOURCE: I forgot my password, and can not log on.
Try to use :), the Password Hint: Remember it could have been a special occasion(s), a certain place, a specific thing, a particular place, or a name of something valuable, or someone special.
Alternatively, just post your IP address, and I'll hack it for you haha..hahaha.hahah
