Question about Refrigerators
Wiring diagram for kenmore elite refrigerator
arikrom
  • 528 Answers
SOURCE: Kenmore Elite refrigerator not cooling
no no put it back to normal setting!!! now is the freezer side cold? if it is cold you need to open it give me your model # and i help you arikrom@gmail.com
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite refrigerator freezer won't close tight.
Head over to the manufacture's website. www.searspartsdirect.com
Enter your full model number in, and you can see expanded diagrams and part ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
bobicehouse
  • 1524 Answers
SOURCE: need wiring diagram for kenmore elite refrig-
http://appliancedigest.com/index.php?/files/file/498-16025629-maytag-amana-bottom-mount-refrigerator-service-manual/
Posted on Nov 03, 2010
SOURCE: kenmore elite refrigerator, very hot between doors
Mine was doing the same thing. I pulled the cardboard cover off the back near the bottom and found the fan was not turning and lots of dust buildup. I unplugged it and vacuumed it out and spun the fan by hand and plugged it back in. The fan started and the temp between doors went down. I may have to replace the fan soon.
Posted on Feb 26, 2011
oldTech2332
  • 2341 Answers
SOURCE: Having problem with Kenmore ice
The wiring diagram your seeking is NOT published on line,i can give you a list of potential problem causing ice not to be made
1) gear on i/m is broke,remove cover on i/m and check if main drive gear is cracked
2) the water inlet valve,rotate fingers on im till it starts turning, access water valve on rear of refrig.
let i/m make a complete 360 degree cycle at one point (toward the end) thier will be 120 volts to
valve,if 120vac to valve and water pressure good at vavle,replace defective valve(unplug valve
and place meter leads into plug/one lead on each wire)
3) a internal switch on i/m, if it makes 360 degree cycle and 120 not to valve,one of switches is bad,
the parts down break down doesn't tell which is for water valve and w/o diagram i dont know the
color wires on switch that sends 120vac to i/m so replace all 3
4) the internal i/m cam that attaches to above mentioned gear is ground down and not closing the
correct switch whe it is supposed to be closed,remove gear and metal plate on i/m if cam is
grooved and gouged up,replace cam
part#s
gear WR29X5162
water valve WR57X10033
switch(s) WR29X5171
cam WR29X5167
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Posted on Jul 30, 2011
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
I need a wiring diagram for a Kenmore Elite refrigerator
Did you check the places that they hide them on frig
1 on front grill under doors
2 on the back tucked iI side near compressor
Hope this helpd
Jan 24, 2015 | Kenmore Refrigerators
What does Kenmore refrigerator error code er co mean?
I just did a google search. It seems that it is a communications error between the computer in the back of the refrigerator and the front panel display,. Some people have replaced the computer only to find that the problem stays. At least two have found that wires have broken in the front door.
The wires get flexed when the door is opened and closed.
Use your model number at the sears parts direct to see user manuals diagrams and parts lists. Link below.
http://www.searspartsdirect.com/
Sep 06, 2014 | Kenmore Elite 29 cu. ft. Grab-N-Go French...
10674206400 wiring diagram
I am sorry but we do not have wiring diagrams here.
Sep 10, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Need wiring diagram for kenmore elite refrig- 596.765295001515031
Nov 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Need replacement evap fan part# for Kenmore Elite
Enter your full model number in, and you can see expanded diagrams and order parts.
Mar 27, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite refrigerator freezer won't close tight.
Sep 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
