How can I set the correct clock time on an iHome HP9?
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
How do I Set time on ihome HPL10
This is a hotel version of the iHome iPL10 which has the Set Clock button on top. Instead, the set/sync button is on the back of the unit. This is typically covered by a plastic cover to keep guests from messing with the time settings on the clock. The covered buttons allow you to set Volume Limit: high or low, Time: set/sync, and Day Light Savings Time (dst) +1 -1 or Auto.
Since this is the hotel version, there is no User Manual on iHome's web site.
Jun 13, 2014 | Pioneer DXT-2266UB Car Audio System
My ip9 ihome will play music from my ipod touch but it will not charge it. What can I do to fix it?
there is no way to charge it and play it at the same time, unfortunately, iPod touch is not supported for that format, only the latest nano and below.
Jul 08, 2011 | iHome Clock Clock Radio for iPhone iPod...
Ihome--ih8,
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
Jul 08, 2010 | iHome Ih8 Dual Alarm Clock Radio For Ipod...
Remote won't control my 4th generation ipod nano
Hey I figured it out. When you bought the 4th generation ipod nano it came with it's own dock insert. It fits perfectly and fixes everything, including the remote issues. Now my only problem is I have a black ihome and a white insert :( Good luck!
Dec 26, 2008 | Dual Electronics ihome iH9BR iH9 Alarm...
 Grubhead
Grubhead
