Question about GE Refrigerators
I have a tfx20jr,tft20jr ge refrigerator that is not making ice or dispensing the water
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 54 Answers
SOURCE: Broken ice maker in a GE side by side refrigerator
Most of the time the spring just pops out of the keeper on the ice maker, If you push the feeler arm back and it does not come back out on its own then the spring has poped off. Look where the feeler arm attaches to the ice maker and there is a round spring between the feeler arm and the icemaker housing. There is one hole in the feeler arm ans one on the ice maker housing that the spring pops into. Its usually the spring is out of the hole on the ice maker housing.
Posted on Jul 03, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
SolutionGuy
  • 331 Answers
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
No water or ice coming from the dispenser, ice is being made. Cannot change the freezer temperature
Fix your GE refrigerator door ice and water dispenser ...
? 18:47
www.youtube.com/watch?v=8yNWbNaNCOA
Oct 20, 2013 - Uploaded by StewTube
Fix your GE refrigerator door ice and water dispenser and save ...it makes ice but no water or ice come out from the dispenserAnd if it's the ...
Oct 24, 2015 | Refrigerators
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
Ge tfx20jr icemaker not working
First check that ice maker is on. Check ice maker water valve and make sure freezer is freezing. Is there ice in the ice maker? If so its not harvisting replace ice maker
Aug 22, 2013 | Refrigerators
ICE MAKER QUIT WORKING ON GE 19.7 TFX20JR BUT WATER STILLS WORKS
you have a dual valve one side quit working. get a new inlet valve.
Aug 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR Have ice but no water
you have a duel water supply valve on the back bottom of frig.,the water dispenser side might be bad,or you have a micro switch behind the water dispenser that could be bad,check both-mike
Nov 20, 2008 | Refrigerators
Ge refrigerator makes ice but does not dispense ice
FROZE UP RESEVOIR BEHIND REFRIGERATOR DRAWERS. PULL OUT FRUIT AND SNACK DRAWERS AND DEFROST WITH BOILING WATER OR A HAIR DRYER.
Nov 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
