Question about ZT Group Cisnet PC Desktop
Browser running slow in cisnet pentium 4 processer
I have tons of memory (50 G free space) and have upped the RAM allowances and run degrag. It is still very slow and won't let me run more than one thing at a time, or more than one tab on my browser.
  • Henry Shivley Feb 29, 2012
    I performed a clean install. I still have the same problem. I think I need to purchase and install more RAM. I only have 192 mb currently.
  • 62 Answers
Hard drive has a bad sector probably try a new disc or borrow one clean install and see if it corrects performance 99% sure thing
Posted on Feb 25, 2012
May 25th my CISnet computer would not start Windows, a file was missing. I did not have my Windows CD so I let the CISnet do the Restore. Can I undo the change after my CISnet computer restore to original...
Try the following;
1. Press "Start" on your Cisnet computer's desktop screen. Scroll up to "Accessories," then hover over "System Tools." Click on "System Restore."
2. Click the option that allows you to select a different restore point, rather than using the default restore point. The program will display a calendar.
3. Select a specific point to restore your Cisnet computer to by choosing a date from the calendar display. Click the "Next" button to confirm, then click "Finish" to close out system restore. Your Cisnet computer will restart and open with the selected settings.
Be sure that you do not unplug your Cisnet computer while running system restore because it will need sufficient battery life to complete the program.
Jun 02, 2011 | Computers & Internet
Tip
My laptop is running too slow.
Hi.
The most common reason for a computer running slow is insufficient RAM memory.
Check specifications on manufacturer website to find out the kind of memory supported and the maximum RAM allowed.
A computer running Windows Vista should have at least 2 GB to run smoothly.
Increase the RAM, if RAM available is no more than 512MB, then it must be surely and immediately upgraded.
Check also your hard drive free space. If you have less than 1GB free space on hard disk, Windows will have to write continuously virtual memory pages to hard disk, and that will slow down the processing speed. Also check fragmentation. Files pieces may be distributed in different areas of the hard disk, resulting in slower reading speed.
Go to
Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk if needed.
If you have at least 1 GB RAM on XP or Linux, and 2 GB on Vista, and you took care of your hard drive, then you can check the processes that are starting up automatically and remove the useless one, or spot malaware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
on Apr 08, 2010 | Computers & Internet
System running very slow. Please help.
Usually when systems run very slow it is as a result of tons of underground processes which are not authorised by the user. Easiest way out try to uninstall all the applications on your PC which are not in use. This should ease up space on the unit.
Also you can reduce renove certain startup programs which are not needed.
Hope this solution has been helpful?
Nov 28, 2010 | Sylvania G-Netbook
I have a NASCAR themed pc and although it runs fine it is very slow and it didn't used to be. I have cleaned out all the spyware and adware. I have checked and double checked for viruses. So far there is...
As far as cleaning up the operating system, it sounds like you have already done mostly everything. I do have a completely free program that would take care of the last two things, system junk files, and registry errors.
Click here for Ccleaner Free
Other than that, the one thing which would help the most is adding more memory to your PC. Would not cost much and is the easiest piece of hardware to install. Takes less than 5 minutes to do.
Thank you for choosing Fixya.
-Daniel
Sep 28, 2010 | ZT Group Cisnet PC Desktop
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
Nba 2k10 is really slow on my computer, i just got the game and its the biggest thing i have on my computer probably. i have tons of space left, why is it so slow when i go into quick games?
Its not really a question of hardrive space. Its of RAM and graphics card memory. Your computer has 3 gigs of ram and the game requires one however if you have other things running while your playing they will also take up ram and when all the ram is being used the computer will run slowly. Try not to have anything running while you play the game and see if that helps.
If its still slow it could be because of video memory. Try to play in low graphics detail which will make it easier for the computer to "process"
Hope this helps.
Mar 09, 2010 | HP G60-235DX Notebook
Pc working slow. i have done disk clean up deleted temp files .scanned pc with 3 antivirus but none detected any threat .i have 1 gb ram and 80% free hard disk space.i have downloaded ccleaner and fixed...
Dear Sir,
go to hyttp://xviruslab.blogspot.com and go to System Utilities find PC Booster download and install and run a auto run it will clear all your problems
bye bye
keerthy
Sep 29, 2009 | Computers & Internet
Which is the best processor
If ur gonna use the old PC, Upgrade the RAM to at the very least 1gb and you'll be fine. if your looking for a new pc, the intel i7 or the amd phenom x2 are great processors.
Jul 27, 2009 | Intel Pentium 4, 2.53 GHz (SL6S2)
Compaq Presario S4300CL PC Desktop is SLOW.
You said you have 512K of RAM; I assume you mean 512MB. Either way, you are in dire need of a RAM upgrade. The sweet spot for XP memory-wise was 2gigs. The working minimum is 512MB, but the recommended spec is at least 1. If you upgraded to at least 2 gigs of ram, you'll see a speed improvement.
If you need help finding out what type of memory to get, let me know.
Mar 14, 2009 | Compaq Computers & Internet
Too slow
the only way to improve graphics is to upgrade your graphics card and ensure that you have enough system memory and proccesor power to run the game as it should do. If you have a 32MB or 64MB card then maybe you should go for atleast 128MB
Oct 02, 2007 | Microsoft Windows XP Professional With...
ZT Group Cisnet  PC Desktop Logo
88 people viewed this question
Top ZT Group Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
didi2005
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
