Question about Whirlpool WMH2175XVB Microwave Oven
Whirlpool microwave The lights work, vent, turn table, timer n time but the microwave won't heat the food. Please help thanks
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool microwave MH1170xsy0 1000 watts
With the symptoms you mention, I would suspect:
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 21, 2008
bestdarngood
  • 3037 Answers
SOURCE: My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
heavyt15
  • 91 Answers
SOURCE: Whirlpool MH1150XMB-0 runs but does not heat food
hmmmmmmmmmmm heat cook spin..jump up and down....myh guess magnetron..is gone
Posted on Aug 18, 2009
Testimonial: "Helpful. I now know what's wrong and think I probably can't fix it myself."
  • 2468 Answers
SOURCE: whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Posted on Jul 28, 2010
  • 11800 Answers
SOURCE: Microwave runs but won't heat
No reset button, there's nothing to reset in it. If you don't get heat and everything else is working that means that the magnetron tube isn't working.
The tube doesn't work because either it's defective ir it isn't powered. To check which you must open the oven and test the power to the magnetron.
Beware, if you don't know how to do that safely or you don't have a very good voltmeter then don't touch it, the very high tension inside can easily kill you.
Posted on Aug 24, 2010
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
Microwave will not heat
hello,
what this mean it that your wave has develop a disconnection problem internally from the wire what you will have to do to fix up your wave is to unscrew your wave then trace the wire down to the element (heat provider) it is silver in colour
please if there is no disconnection in it then it means that the element has gone bad then you will have to make a change of it with a better one you can get it in the store
please make sure that all form of power supply is put OFF before you can carry out this function.
Good lock ,thank you and thanks for using fixya.
Jun 01, 2010 | GE Spacemaker JVM1740 Microwave Oven
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
Benjamin
May 25, 2009 | Whirlpool MH2155XP Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Whirlpool WMH2175XVB Microwave Oven Logo
97 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
