Question about Epson Workforce 520 Printer
Epson workforce 520 won't recognise ink cartidges
Purchased new epson cartridges yet the printer will not recognise them and print. any suggestions on how to get the printer to recognise the new ink. These are not refills.
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Posted on Jul 26, 2012
I have the same problem with my workforce 520. He won't reconize the black ink cartriges. The original ones worked nicely but i refilled them and then it stoped working. Can i have some help plzzz !
Posted on May 01, 2012
  • whyteknight6
    whyteknight6 Jul 26, 2012
    After struggling, I noticed some of my refill cartridges had 7 gold metal contacts on one side, while some had 9. They were otherwise idential. The one with 9 was throwing an error on the printer's display saying something like "...not recognized... BK1". Make sure all cartridges have the same and correct number of gold metal contacts (7?).
57 varieties
  • 1653 Answers
SOURCE: Epson DX8450 Stylus not recognising Jet Tec inks
Buy a Universal Resetter for Epson Intelligent Ink Carts and follow the instructions. They work like a dream! Freely available from most third party cartridge dealers and eBay.
Posted on Aug 29, 2009
jackboy
  • 2985 Answers
SOURCE: Epson RX560 ink cartidges not recognised
Report this to Epson Support.
Remove all cartridges and switch the printer off
Reinsert and retry.
Download the Epson utility www.ssclg.com
and use it to Reset counters.
Posted on Feb 11, 2008
  • 6 Answers
SOURCE: Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Posted on Apr 15, 2009
websnail
  • 419 Answers
SOURCE: Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
Posted on May 06, 2009
  • 11 Answers
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
Scanner Error - After installing 1st time Remanufacatured Ink Cartridges
Remanufactured cartridges have too many problems. I have be using refillable with auto-reset chips and never have a problem. Google- refillable cartridges and be sure to use the proper ink, dye base or pigment. It makes a difference.
Apr 09, 2014 | Epson Workforce 520 Printer
Epsom 520 printer problem
Bad printer nozzles, faulty cartridges and or ink.
Mar 19, 2014 | Epson Workforce 520 Printer
Ink cartridge on epson workforce 520 is not over enough to change how to I move it
Hi, please try the following to resolve this issue.
Open the scanner unit and check for any jammed paper or foreign object that is blocking the print head movement. Then click the link below and follow the steps regarding remove and install ink cartridges in the Epson WF520 user's guide.
http://files.support.epson.com/htmldocs/wf520_/wf520_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 14, 2011 | Epson Office Equipment & Supplies
I put new ink in it, now it won't print, it is
If you only filled the cartridges with ink they will not work.
The chip on the cartridges needs resetting.
To do that you would have to buy an Epson cartridge chip resetter..
Feb 20, 2010 | Epson Workforce 30 Laser Printer
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Cartidge problem
Many "compatible" cartridges are badly manufactured or even labeld wrong. These can damage or block the connectors on Epson printers. your best bet is go buy new ink and try them, then if it still dont recognise, you could buy some ink cleaning cartiridges and give them a try - Google "Epson Print Head cleaning" Failing that go buy a new printer - Epson's are real cheap new.
Sep 08, 2007 | Epson Stylus C48 InkJet Printer
Epson Workforce 520 Printer Logo
4,497 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
