Question about Sony VAIO Digital Studio PCV-RZ22G PC Desktop
Task manager I have a problem with my task manager. I cant open. It is being disabled from the task manager windows. Perhaps it is being blocked by SSCVIIHOST internet virus . The moment i open up my somputer, it directly pop up with the SSCVIIHOST.exe. Can you please help me solve this problem
  • 488 Answers
Looks like the work of a virus..download task manager fix from http://www.taskmanagerfix.com/ and use..dont forget to do a full virus scan after turning off system restore..hope it helps
Posted on Oct 28, 2008
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Had a virus got rid off it but now screen is white and cannot do anything with it
Task Manager is disabled. We want to enable the Task manager in my computer
If it (Task Manager) was not disabled by the Administrator (in case your computer is on a network), you can easily enable the it. But you need to know that this could also be done by viruses. As we know, this issue is often created by virus. So I would suggest you to run a full system Scan using an updated antivirus (for this problem, I would recommend you to use Avira free antivirus, you can download it from avirafreeantivirus).
To enable the Task Manager, follow the below instructions:
Click “Start” > “Run” and type in “gpedit.msc” (without qoutes) and press Enter.
Group Policy Editor window will open, once it’s opened, follow the steps by clicking your mouse as labeled here (sequence 1, 2.....):
Once you double click the "Remove Task Manager", another window will pop up, click your mouse as labelled below (Sequence..):
After you are done, close the Group Policy Editor and go check your task manager, hurray, it's working.
But that's the end, the problem may return if your system is infected by virus, so don’t forget to run a Full System Virus Scan using an updated antivirus.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | Computers & Internet
'Task Manager' and 'regedit' cannot be opened.
it arises from the policy fault
type gpedit.msc in run and disable the component that seems to be faulty.
Feb 14, 2010 | HP Compaq Presario V5000 V5100 V5200 V5300...
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Computer
Well, your problem seems to be due to a virus attack. Certain virus disable your task manager. To solve this, scan your computer with a good antivirus software and remove the virus. But in most cases you won't be able to restore the task manager with the antivirus application. So the best method is to backup your documents on the the drive where OS is installed and reinstall your OS.
Jan 05, 2009 | Computers & Internet
Task manager
If you are certain that you are logged on as administrator or has administrator privileges, then a virus is preventing your opening of the Task Manager. Additionally, the same virus is likewise preventing access to the Folder Option and the MSCONFIG function.
Of course the correct solution would be to run a full deep virus scan and delete detected ones. You can also try running RRT.exe to force access to the above functions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Microsoft Windows XP Professional
Serious TaskManager Problem!!
Task Manager can be disabled by 2 main ways..
[1] Either there is a virus on your machine--
[2]Or It was manually disabled.
--The 1st solution is to get an anti virus which is up to date and run a virus scan to delete the viruses that maybe present.
--The second solution is that on your START MENU, click on "run".
On 'run' type "gpedit.msc"..
Under the "User Configuration" , click on " Administrative Templates"..
Then you double click on "system" .Double click on "Ctrl+Alt+Del Options"... Double Click on " Remove Task Manager" and click on "Disable"... Click on "Apply" and "Ok"
Your Task Manager should now work !!!
Jan 03, 2008 | Computers & Internet
Sony VAIO Digital Studio PCV-RZ22G PC Desktop Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
