Question about Dometic Rooftop RV Air Conditioner
Duo therm runs cools clicking
Unit starts ok cools good, fan works good, unit starts clicking i changed the control box, changed the thermostat still clicks
  • 1 more comment
  • Ken Miller Mar 07, 2012
    The problem was the remote sensor trying to change the fan speed. Replaced sensor no more clicking.
  • XXXREX
    XXXREX Mar 08, 2012
    What do you mean ,"control box" specifically? "There is no control box"having just ooked at the website for Duotherm to see what you had specifically, heat pump, or if they had a strip only model. I see you included no model # as wel, so thet "box"
    I am assuming meant the 2 switches .OFF,LO,MED HI,COOL, HEAT, MODE,
    and the WARMER-COLDER, types for the manually controlled units with no remotely mounted thermostat, as in a home thermostat and not a WARMER-COLDER dial, I have the remote thermostat dou therm in my rv, it has a circuit board, is that what "control box" is? The thermostat is the same universal red white yellow green and common as all others, That inability to troubleshoot a thermostat yet be confident enough to diagnose and replace the "box" is incongruent, as is the "remote sensor" "trying" to change the fan speeds?? No such animal exists nor is that any normal sequence of operation regardless of the model #.
    The assertion doesnt exactly inspire integrity in my ears, theres too many vague incongruencies, and factual errors to be taken seriously at this juncture. I apologize if I aam corrected by a specific qualificationIE actual parts names/#, model#, actual description of components and the actual symptoms that coincide with the normal sequences of operation. I look forward to the actual specifics of what actually happened.
    control box, ? What do you mean specifically
  • KD Grayson Heating,Air conditioning & Refrigeration
    ridiculous.
  • 499 Answers
Sounds like a reversing valve solenoid.
Posted on Feb 25, 2012
  • 50 Answers
SOURCE: fan will not come on
maybe the capacitor for fan was already busted try to check that.
Posted on May 17, 2009
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
SOURCE: I have a dometic duo-therm. No air coming through ducts.
I have a new Montana Mountaineer with a Dometic Duo Therm as well and experience something similar.
It appears that there are two options:
1. Open the vents in the unit and all the cold air will blow out of the AC as that would be the shortest path and the there is hardly any air coming out of the ducts.
2. Close the vents in the unit and it will force all the air through the ducts.
We let the air blow straight out of the unit during the day and then force it through the ducts at night to force it in the bedrooms. You could also open the vents in the unit part ways to get a combination.
I didn't figure it out immediatly either, but just look close at the unit and you can see that you can close the vents on the unit itself
Posted on Apr 20, 2009
22yooper
  • 828 Answers
SOURCE: duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Posted on Jun 28, 2008
SOURCE: Duo-Therm air conditioner/thermostat problems
The solution was to purchase and install a new thermostat. Works perfectly now.
Posted on Jun 02, 2009
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
398 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
