Question about Maytag Washing Machines
I have a Maytag MAF 1200AAW washing machine that does not spin at high speed. The pump is pumping out the water and it spins slowly but will not spin fast enough to rid the clothes of excess water
  • vk4tdk Oct 29, 2008
    Thankyou for the reply.I had already checked the filter and found it to be okay.
  • 101 Answers
Check to see if the waste water filter is clogged, look in the manual for this.
the filter gets clogged with hairs,buttons etc...
Posted on Oct 28, 2008
My washer machine working in all function but in the spin function the motor rotate slowly
there is a problem in the program board
the unit starts to spin slow as the water is pumped out
that is supposed to distribute the clothes for balance and then it goes into a high speed spin
you unit is not progressing to that high speed spin
Call a technician for a proper diagnosis and fix
Nov 06, 2016 | Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Commercial maytag front loader starts high spin when money is put in
It's A You Drain Pump is bad. What a guy! He did not know that!? Replace the drain Pump and it will a Happy washer again!
Jan 19, 2014 | Maytag Washing Machines
My wife put a heavy load into the machine. Though the machine spins slowly the spin cycle does not remove any water. Is the motor going bad or is there something wrong with the pump that removes the water?...
There are two motors- the drive motor for the basket and a seperate drain motor for pumping out water. It there is standing water in the tub it is possibly a bad drain pump or plugged(say a kids sock) If you pull the drain hose slightly up out of the stand pipe while it is draining and there is full water flow your pump is fine. (will not spin with water in tub) (door lock also needs to work)
There are some out of balance switches on machine to limit speed in spin. Need to manually test.
The tech sheet is probably in the back of the console controls. To check the main motor involves removing the front panel and the p4(by memory, do not quote me on this) connector on the motor control board in the base. Working on the main motor is more involved, not going to cover all the testing neccessary with just your description of problem. Nice washing machine, but there are easier ones to service.
Hope this helps
Jan 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
Maytag washer. Model PAV1000AWW: It won't spin. Agitates OK. Water pumps out OK. Just won't spin. Makes no unusual noise. Bad transmission?
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Sep 06, 2008 | Maytag Washing Machines
Gltf2940es1 won't spin
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Mar 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
