Question about Boating
Need help! I have a 2003 kawasaki stx 12f that won't start. Replaced plugs fuel pump. Has fresh tank of gas. The gauges went out (leaked water inside gauge). Do I have to replace the gauge or should it start with the bad one?
  • 7 Answers
SOURCE: Fuel Gauge Not Reading
you might wanna check the contact on the floater i had that problem so i just bent the contacts closer and that worked for me
Posted on Nov 19, 2008
emissionwiz
  • 79865 Answers
SOURCE: Fuel gauge broken on 2003 Audi A4
You have a fuel gauge sending unit problem, the gauge is not the problem, the sending unit is in the gas tank, u must remove the gas tank to replace it.
Posted on May 28, 2009
  • 7353 Answers
SOURCE: 93 gmc sierra 5.7 liter engine, injection carb,
you say you replaced the fuse, but does the fuse have power? the gray wire at pump should have power when cranking, or for 2 seconds when turning key on. At fuel pump relay, put power onto gray wire, the pump should run if the wiring is good. if it doenst run then ck for power at fuse while power is on gray wire.
Posted on Oct 19, 2009
SOURCE: 1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Posted on Jul 20, 2010
SOURCE: How to turn on the SLO mode on the Kawasaki STX-12F Jet Ski
2003 kawasaki stx-12f jetski wont start.
Posted on Apr 23, 2011
2003 Kawasaki Vulcan 800 classic has a fuel leak from the carburetor
Hi, Carlos and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Vulcan 800 Leaking Gas
carb issues overflow excessive fuel Kawasaki Vulcan Forum Vulcan Forums
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Jun 12, 2017 | 2003 kawasaki VN 800 Vulcan Classic
03 KAWASAKI STX 12F SKI HAS NO SPARK AND NO FUEL HELP
HAVE YOU CHECKED ALL FUSES? DO YOU HAVE BATTERY POWER? IS THE POWER GETTING TO THE IGNITION COIL? DOES IT GO PAST THE COIL TO A REMOVED SPARK PLUG THAT YOU LAY CONNECTED TO ITS CABLE ON THE ENGINE FOR GROUNDING; DOES IT SPARK WHEN YOU ACTIVATE THE STARTER?
Jun 20, 2015 | Boating
2003 Kawasaki KX 125 carburetor not getting fuel
Hi, Anonymous you need to locate the fuel flow origin first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing.
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn.
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working.
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KX 125 won start have tried everything
What to Do Check When Dirt Bike Won Start
Kawasaki KX125 Service Manual
2003 Kawasaki KX125 Owner Manual
Jan 06, 2014 | 2003 kawasaki KX 125
My truck turns over but won't start...not enough pressure in fuel pump.
Will it start if you poor some gas down the throttle body? If so then it is a fuel problem. There are some things that will need to be checked. First you need to take a fuel pressure test. If you don't have the equipment to perform the test you can borrow it from Auto Zone. After the gauge is hooked up turn on the key and watch the gauge. It should clime to about 40 PSI (find out what the spec's are for your truck) If it doesn't clime check for restrictions in the system - fuel filter, kinks in line or leaks. The filter in the tank on the end of the fuel pump could be plugged. But before you go pulling the tank check the pressure regulator on the fuel rail it could be allowing the fuel to return to the tank. Another possibility is a stuck fuel injector. If everything checks OK then change the pump.
Apr 12, 2013 | 1996 Ford F150 Regular Cab
97 mercury mountaineer. won't start
hi,
watch your oil pressure when cranking, you have to have some oil pressure to get the fuel system to start. you may have to find the hot wire at the relay and energize it to see if it is indeed the fuel pump going out. if its been sitting and its a 97 the fuel pump just might have went, you can also try hitting the gas tank from the outside in the middle to see if that works too. have a water hose or fire extinguisher around when your working on fuel system and leave one of your battery cable a little loose..
jm
Jul 04, 2017 | 1997 Mercury Mountaineer
Will not start wnen less than one fourth tank of fuel. 2003 Yukon
Do you park on a hill? Try pumping the gas pedal a few times before you start it. Check that there is no fuel being dropped, check under the car for rusted fuel lines and any drips.
Hope this helps and vote for me please Thanks.
Jun 24, 2010 | 2003 GMC Yukon
Car won,t start, getting fire from the module,gas is coming up to
have you checked the fuel pump, or the timing, or coil pack, or fuses?
Jan 09, 2009 | 1995 Buick Park Avenue
Boating Logo
96 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
