Question about Dryers
Aloha How do you get into the MAYTAG Neptune Dryer MD55? THank you.
3 Suggested Answers
  • 32 Answers
SOURCE: My maytag neptune dryer will
Try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button.
2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction.
3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced. If it is still under full warranty, simply call a repairman.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Amana certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Posted on Aug 03, 2010
SOURCE: I have a Maytag MD55 dryter and one of the paddles
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
Posted on Nov 03, 2010
Why is my Maytag Neptune Elec Dryer MD55 chirping? How can I fix it?
Could be a bad spot on the drive belt. Each time it moves over the motor pulley it slips. If the chirp is happening at the same interval over and over I would check the belt.
Mar 28, 2015 | Maytag Dryers
Md55
Are you getting any heat at all in the unit?
Apr 28, 2012 | Maytag Neptune MDE5500AY Electric Dryer
WHERE CAN I FIND PEDESTALS FOR MAYTAG NEPTUNE WASHER AND DRYER MODELS MD55 AND MAH-1 MODELS?
Don't...Unless you have a concrete floor you will never be satisfied with the pedestal. Your front loader will shake a lot more. People buy these things then I go to there house with a "shaking" problem and then they get mad at me because I tell them it's because of the pedestal. Front loaders were designed on concrete floors so they're only going to work like they say on concrete floors. Do a little research before you make that decision please. Not to mention they're about 200 dollars or more. Just a heads up I don't mean to bring ya down.
Apr 02, 2011 | Washing Machines
Have a maytag neptune dryer md55 cannot get a small enough tool to adjust legs to help balance. any suggestions
use some ceader shake shingles ther tapered and the bugs hate it and it smells good this will shim the unit and break off what you don't need. hope this helps
Aug 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
May 14, 2010 | Dryers
Drum rotates and only occasional heat
The problem is the dryer coils are failing. They tend to fail as they heat up. These are inexpensive and easy to replace.
There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Is there a reset code for maytage neptune MD55?
There is not a reset button but you have a control board that controls all the commands and functions on this model.
You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we can overnight the correct parts to you after we know what your dryer is not doing right.
We hope to get you drying clothes ASAP.
Thanks, Ella
Nov 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune MD55 elec dryer chirping noise
I would think it might be the "board" but I once went on a call for the same chirp on an oven...ended up being the smoke detector was low on battery..it cost them $$ for me to find that simple thing.
Oct 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
