Question about Samsung Computers & Internet
I was working on my laptop samsung Q430 and it suddenly turned off . Its boots to the windows stage and then blanks out(blue screen)..I have tried to reboot and recover it several times but it still is coming up with the blue blank screen and I can see the mouse arrow moving. Please help
  • OLA Feb 24, 2012
    I tried all this options but it still takes forever to boot. It wont even boot in safemode or last known boot .It brings up the "your pc had a problem booting,startup and repair" or start normally option. And when I go with either one. It just takes a long time to boot and then to the blank blue screen with the mouse cursor pointing.
  • Michael Green Feb 26, 2012
    When you have the mouse pointer on screen and a blue backdrop it is usually because the OS is going through a repair attempt. If this continues for more than an hour, you would be better off doing a re-install.
  • 3,799 Answers
The blue screen (BSOD) is usually caused by a new piece of hardware or driver. But there is a code on the screen which will give you more information about the problem. Put the code into a websearch site and the possible cause should be given.
Posted on Feb 24, 2012
3 Suggested Answers
virtualhost
  • 2185 Answers
SOURCE: After getting an error message about Microsoft has
Try to boot from "Last known good configuration".
Reboot your computer and press F8 until it gives you the option to choose the Last known good configuration.
Select that and press Enter.
Tell me if this works; if it didn't we can try other solutions.
Posted on Sep 10, 2009
eagle338
  • 4889 Answers
SOURCE: Computer boots to password screen.
Does this mean that that the display is normal till you come to the password screen? If yes then can you please confirm whether you are able to bootup in safemode? To enter safemode, restart the system and keep pressing "F8" till you see the advanced start up options. Choose safe mode and bootup, see if it comes on and let me know.
Sai.
Posted on Nov 19, 2010
Samsung q430 stuck splash screen
Unplug, remove battery, plug in, try to reboot. If that doesn't work, unplug open Memory Bay, reseat Memory Mods. Open the HDD bay, reseat the HDD. You may have jarred something loose. One can only hope you didn't damage the HDD.
Jan 12, 2013 | Samsung Q430 Laptop
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
http://www.laptopjacks.com/part/Samsung-Q430-DC-Power-Jack-J-SM371300C1.html
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Regards,
joecoolvette
Sep 10, 2011 | Samsung Q430 Laptop
After windows screen it goes blank, i know the lcd works because i can choose F2 or F12 and read and choose anything there however when i command it it just goes blank, no cursor, just blue / black ..blank
If the system will not complete boot, try the F8 boot menu and select safe mode and see if the system will boot to windows.
If the system boots to windows, you could have software issues or a startup item causing the system to hang at boot, try turning off the startup group items in MSCONFIG (Start, run, MSCONFIG) and see if the system will boot in normal mode.
If that is not help, hold the Fn Key while pressing the power buttong this should start PSA diagnostics on the system, see if any hardware fails
Jun 30, 2011 | Dell Inspiron 5100 Notebook
Brandnew Samsung Q430 freezes regularly for anything between a couple of seconds till several minutes, in any programme which is then displayed as 'not responding' while the harddisk light is continuously...
It sounds like your hard drive is defective and not working properly, you pointed out this is brand new machine and should be under warranty, if the vendor is not prepared to back what he sells, I suggest you get in touch with Samsung to see if they can remedy the situation because you should have a manufacture warranty on the product.
Apr 15, 2011 | Samsung Q430 Laptop
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Laptop screen turn blank
Are you using the nVidia GeForce GO 6150 video card? If this is the case, and I'm pretty sure it is, the NV driver is not being recognized and the system is starting in VESA.
On the nVida, HSYNC/VSYNC frequencies need to be specified, after that the MIXIMUM resolution of 1280x800 should work for you.
Mar 30, 2008 | HP Compaq Presario v3000z Notebook
Computers & Internet Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
