Question about ASUS P5KPL-AM SE Motherboard
P5kpl am-se stops during boot
When i power on my motherboard, it stops at the motherboard banner and i have to power it off and back on again
The motherboard may be dying.
Posted on Jan 29, 2013
SOURCE: how can i install audio device in p5kpl-am se
i want to sound driver
Posted on Aug 14, 2009
SOURCE: ASUS P5KPL-VM does not start, blinking LED
u must repair ur mother board there is problem of power section . power ic get heat and than only working.enjoy good luck plz vote on my comments
Posted on Sep 03, 2009
  • 263 Answers
SOURCE: Asus p5kpl-cm boot problem
Could possibly be a fault on your hard drive the same happened to me ,I checked the hard drive on another pc and it was dead..Good luck John
Posted on Aug 02, 2009
  • 10406 Answers
SOURCE: Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Posted on Sep 11, 2009
  • 209 Answers
SOURCE: where can i download the drivers
you can get drivers from www.driversguide.com
Posted on Dec 31, 2009
Testimonial: "thank you very much "
Have blink 4 times
Hi , your mainboard uses AMI bios , "4 LED blinks" during POST appears to be a system memory related issue, some installation or compatibility.
If the display is viewable I suggest run a self booting system memory test to test installed ram memory
Oct 25, 2015 | ASUS P5KPL-AM SE Motherboard
Asus motherboard no boot
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
Try to renew the power supply.
Try also to add a graphic card, on the mainboard instead useing the onboard graphic.
Here is a fault finder guide, when no display:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Feb 13, 2013 | ASUS P5KPL-AM SE Motherboard
USB Booting
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to your desired device ,press escape then press f10 to save to cmos to restart
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Jun 29, 2012 | ASUS P5KPL-AM SE Motherboard
My mother board on desktop is P5KPL-AM SE it is not detecting hard disk after installing windows on new hard disk it goes on repeatedly rebooting never shows windows if i tweek bios setup the windows...
check you bios setting
1st boot should be your hard disk if your hard disk model is not shown in the selection then select HDD-0 as your first boot this will solve your problem
this solution only works if your hard **** is detected during POST if not detected check the power connector and SATA or IDE cable of your Hard Disk
Sep 21, 2011 | ASUS P5KPL-AM SE Motherboard
Hi it has bios 0603 but it need new bios and i can not find it
if you mean that you cant
hope this helps
Feb 21, 2011 | ASUS P5KPLAM SE Motherboard and Intel Core...
Hello, i have problem with booting. i need twice booting to run my computer. first boot PC is running but no display output (no beep). second boot (after i shutdown the PC), my PC is working fine (with one...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
don
Feb 13, 2011 | ASUS P5KPL-AM SE Motherboard
I updated the bios of my ASUS P5KPL-AM SE motherboard. after the update, the system restarted and it cannot boot anymore!! the CPU fan turns on but nothing is displayed on the monitor.. how do i fix this?...
your bios driver is likely to be faulty.
so download a valid driver then update your bios again.
if it doesn't work, intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 15 minutes then connect all of cables and try turning on your pc:
1- with battrey of bios
2- without battery of bios
it should work.
Jan 08, 2011 | ASUS P5KPL-AM SE Motherboard
What is password for bios
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Nov 24, 2010 | ASUS P5KPL-AM SE Motherboard
Drivers for my P5KPL-AM SE mo-bo stopped working for my computer , can't connect to internet , get sound or play games. :(
Go to http://support.asus.com/download/Download.aspx?SLanguage=en-us.
you will get 3 Dropdown Menu's
1. Select Motherboard
2. Select Socket 775
3. Select P5KPL-AM SE
hit search. it will ask for your operating System. you can download all tjhe latest drivers for the P5KPL-AM SE.
Good Luck
May 01, 2010 | ASUS P5KPL-AM SE Motherboard
When i boot up my pc it takes hour and get hang.. and what more is the time i boot up again because it get hang, i cant see the windows logo its faded and nothing happen. what seems to be the problem? and...
try hardware monitor on your CMOS setup, check for any unusual settings, This may help, did you load the cool n quiet software that comes with the motherboard CD.
Jul 13, 2009 | Computers & Internet
ASUS P5KPL-AM SE Motherboard Logo
176 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
