Question about Breezaire WKCE 2200 Wine Cooler
Buy whole unit or replace motor
I have Breezair wk2200 wine cellar cooling unit which is not working. Technician said the fan motor in the back (condenser fan?) has burnt out. His recommendation is to replace the whole unit at a cost of $700. Can I just replace the fan motor? If so where can I get it and who to contact for putting it in? I live in Sugar Land, TX
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
A PAIR OF FAN MOTOR WILL COST YOU$90 DLLRS PLUS INSTALL, ANY ONE CAN INSTALL THE FANS , UNIT WILL HAVE TO BE REMOVED FROM INSTALL, ONCE ON A TABLE DRILL OFF THE RIVETS AND REMOVE COVER, LIFT THE BLUE INSULATION COVER THAT WILL BE EXPOSED AND YOU WILL SE ALL 4 FANS TWO COLD SIDE(EVAP SIDE) TWO HTO SIDE (CONDENSER) USE A PHILLIPS SCREW DRIVER TO REMOVE FANS INSTALL THE NEW ONES AND CLOSE UNIT USING SELF TAPPING SCREWS OR 1/8 RIVETS AND A HAND HELD RIVET GUN.
Posted on Oct 23, 2012
2 Suggested Answers
WCISERVICE
  • 50 Answers
SOURCE: where can i obtain a main control board for a WKE
THE MANUFACTURER WILL SELL YOU ONE CONTACT THEM 858-566-7473
Posted on Sep 16, 2011
How do you open cabinet to replace fans on a Breezaire WK2200 unit?
YOU WILL HAVE TO DRILL OF THE RIVETS ON THE SIDES OF THE UNIT USING A 1/8 DRILL BIT, ONCE YOU DRILLED THEM OF YOU WILL TAKE OF THE COVER ON THE UNIT AND YOU WILL SEE BLUE INSULATION ON IT, REMOVE THE TOP INSULATION COVER AND FANS WILL BE EXPOSED, THEY HAVE QICK DISCONNECT LEADS ON THE WIRES, DISCONNECT THE WIRES, UNSCREW THE FANS WITH A PHILLIPS SCREW DRIVER, INSTALL NEW FANS AND REMEMBER TO TIE STRAP THE WIRES FROM THE NEW FANS TOGETHER SO THEY DONT MOVE.
Jul 13, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
Aug 04, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
How do you know if a cooling condenser needs to be recharged?
Before you can answer that question the equipment must have clean evaporator, clean condensor, all fans working oiled and up to speed. Drain line in evaporator clean and opened. what refrigerant. let me know I can help. Thanks for choosing fixya. wally
Jul 29, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
My 2200 unit stoped cooling why
IF YOUR UNIT IS A WK2200 IT SHOULD HAVE A SCREW ADJUSTMENT(THERMOSTAT) IN BETWEEN THE TWO BROWN GRILLS. IF SO IF THE FANS ARE RUNNING ON BOTH SIDES COLD AND HOT SIDE, AND NO COLD AIR IS BEING PRODUCED YOU PROBABLY HAVE A FREON LEAK AND THE UNIT REQUIRES A RECHARGE AFTER REPAIRING THE LEAK.
Jan 17, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
The unit does not cool anymore. The fan works but the temp is in at 80.
IF THE FANS ARE WORKING ON BOTH SIDES HOT AND COLD AND NO COLD AIR IS BEING PRODUCED YOU PROBABLY HAVE A FREON LEAK
Dec 26, 2010 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Cooling unit is running, but interior is not cool.
How long have you had this unit and did it quit suddenly or did it fail intermittently. Do you mean running where you can hear the fan and the light comes on when you open the wine cellar door? If so, I would suspect the starting relay failure on your cooler which should be very easy to replace. There should be a wiring diragram on the back of your unit somewhere and could be labeled (RT). Your compressor would be the last thing I would suspect.
Dec 05, 2010 | Vintage Keeper 500 Plus Wine Cellar
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
Taking a long time to cool down and when does the fan kick on
the evaporater fan should be opperating when the compressor is runnig ,as well as the condenser fan if you have one
May 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Kitchenaid Wine Cellar-model # KUWS2246EBLO Power on switch does not turn on cooling compressor. Lite will come on.
Try tapping on the thermostat it is probably sticking.
If it comes on then you will need to replace the thermostat.
Check the start relay on the compressor.
Check the fan motor on the compressor is it running?
Clean lint from underneath on the condensing coil.
Mar 26, 2009 | KitchenAid 48-bottle Wine Cellar
Breezaire WKCE 2200 Wine Cooler Logo
159 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
