Question about Saeco Royal Professional Espresso Machine
Flakes/Particles coming out of the steam nozzle.
I have a Saeco Royal Professional coffee machine, and when I use the steamer for either steam or hot water, small dark coloured particles or flakes come out. I have always descaled this machine and kept it rinsed and maintained since I have had it (4 or 5 years). The particles look metalic but I'm not 100% sure. Also, I would like to ask what the water hardness setting does? Thanks
mirran
  • 515 Answers
SOURCE: Steam nozzle leaking
I think you have to replace the steam valve in your machine.
Posted on Aug 04, 2008
SOURCE: how do I descale my Saeco Vienna Deluxe?
Purchase the Saeco descaler. Mix solution accordingly. Pour into water tank. Run a cappucino cup full of water through the wand. Wait about 20 minute and repeat. Do this until all the water is gone in the tank. (Don't run all the water at once!). Rinse water tank well. FIll with clean water and run through the wand. I do this twice just to be sure I have gotten all the chemical out.
Posted on Aug 22, 2009
  • 1089 Answers
SOURCE: saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Posted on Oct 26, 2009
Testimonial: "thanks "
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
Why wont the steamer work
hi,
he pump presses hot water through the grind not steam.
if the coffee is hot and hot water is dispensed, your line are clocked.
descale the machine as directed.
if coffee is cold the heat element is toasted. very unlikely though, since the machine will not dispens coffee, pump running if correct temperature is not reached.
good luck
Aug 08, 2014 | Saeco Royal Professional Espresso Machine
Saeco royal coffee bar steamer doesnt work
Hi there
Have you looked into the steamer to see if the things function there?
I suspect that there is something not working. What does the troublshooting say? Look there ;
http://www.generalmanual.com/Kitchen-Appliances/Saeco-Royal-Coffee-Bar.htm
Good luck
Kolbrun
Mar 05, 2012 | Saeco Royal Coffee Bar Coffee Maker,...
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
Steam building up within the unit/
The steam pipe after the steam solenoid to the steam arm is leaking which it can be cause just becase the support nut is loose. So if you just remove the top plastic panel you can even use the machine and see which point need to tight it up.
Good luck.
Remember top vote for this answer
Mar 10, 2010 | Saeco Royal Professional Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
How to purge saeco royal digital plus
run hot water from the steam nozzle for few seconds
Mar 01, 2009 | Saeco Royal Digital Plus Coffee...
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Ventilate sign on my coffee machine
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Professional Espresso Machine Logo
20 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
