How do you take a Fuji fi-6130 scanner apart?
Trying to replace parts and can't see how it comes apart
5 Suggested Answers
TechSatya
  • 104 Answers
SOURCE: Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Posted on Jul 27, 2010
Testimonial: "Hello TechSatya, The information you have provided is very helpful. We can now notice staple-pins stuck inside the Sensor panel. Thanks a lot."
SOURCE: fi-6130 scanner attached and on; but computer says
Have you installed the Twain driver? You can download it on Fujitsu's website.
Posted on Jan 18, 2011
  • 643 Answers
SOURCE: Hi, I have a
  1. Turn on the scanner, and confirm if it is connected correctly to your computer.
  1. From the [start] menu, select [All Programs]?[Scanner Utility for Microsoft Windows]?[Software Operation Panel].
  2. From the list on the left of the panel, select [Device Setting].
  3. Click the [Clear] button beside the replaced consumable.
  4. Click the [OK] button on the displayed confirmation message.
Posted on Jun 22, 2011
  • 29 Answers
SOURCE: How do you tell the
Set it for "Simplex" in the driver
Posted on Sep 08, 2011
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
Fujitsu fi 6130c sheetfed scanners make a clicking noise, then jam.
Hello Eddie,
The clicking noise could be due to abrasion of gears in the upper part of the scanner.Please check your scanner usage and a general service will resolve the issue with replacement of the gears, if required.You are recommended to contact your local Fujitsu authorised service station for repair. For more information, please visit www.fujitsu.com
Thanks,
ScanCare
Jun 15, 2012 | Fujitsu fi-6130 duplex scanner
Fi-6130 door is lock how to unlock
The ADF Lock Lever is broken and need to be replaced. you are recommended to contact a Fujitsu scanner expert for the replacement. Please let me know your location, so that I can refer you a Fujitsu scanner expert.
Thanks,
Scancare
Apr 30, 2012 | Fujitsu fi-6130 Flatbed Scanner
Drivers fi-6130
Hi Timothy,
What happens when you try to download?Here's clues to what maybe happening:-
  • One cause maybe your PC's installed anti-virus.Disable it first before the download and then enable it after completion
  • The source of the download.Is it from the products support site or from other websites? Make sure the download's from a trusted source.
  • Try downloads from the Fujitsu support site.
  • Make sure you select the driver download that corresponds with your operating system.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu 6130 Scanner speed has gone down considerably
Scanner speeds are dependent on the Computer System and the hard disk capacity. You need to create contiguous and Large space in Hard disk. Delete unwanted files and also run 'disk defragment' to create contiguous space.
S. Mohan, Chennai, India
Aug 30, 2011 | Fujitsu fi-6130 Flatbed Scanner
Hi, I have a Scanner Fi-6130 and it said to replace pick roller,, of which I replaced both of them. it is still coming up "About time to replace Consumable". I keep ignoring it but am afraid...
Jun 22, 2011 | Fujitsu fi-6130 Flatbed Scanner
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
100 people viewed this question
k24674
jasbo
jasbo
