I dropped my laptop and now when i restart it, a black screen appears stating Operating system not found..? what does it mean and how can i fix this problem asap... please help me.
SOURCE: operating system not found
the laptop is unable to read operating sistem from disk - you have to try to insert recovery disk after changing in the bios (you can read on laptop manual how come in bios for changing to first boot is hard disk to first boot is cdrom or dvd or cd ) after that you can try to recovery the operating sistem - it may be not so easy delfo
SOURCE: operating system not found on my laptop
Hi DONNAk123
There are many possible reasons for this problem. The most common of which is corruption of your file system or the "master boot record". (Each having to do w/ the computer's hard disk drive.)
If you could, please, answer the following questions it would help a great deal in determining what the next step to take is.
(01) What is the make of your laptop?
(02) What is the model?
(03) What is the serial number or service tag number (Dell)?
(04) What operating system is installed on the laptop?
(05) Do you have the system restore CDs or operating system CD that came w/ the computer?
(06) Did any event precipitate this problem? (dropping the laptop, installing or uninstalling software or hardware drivers, installing operating system or any other updates, system "crash", etc.)
This and any other information you can provide can be very helpful.
Thank you,
BJ
SOURCE: help on my fujitso siemens MS2212 please...
The clicking is from the hard drive. This clicking , along with the error op system not found, indicates that the drive has crashed or failed. You will have to replace the hard drive.
Unfortunately the OS got corrupted and you need to re install the Operating system.
There is no other way to fix the problem but use the recovery disc.
If you dont have a recovery disc you may want to contact the manufacturer of your laptop and order one.
Or if you can use a retail version of Operating system and once finished installing you may need to download the drivers of your laptop on the support site.
Hope this helps.
SOURCE: Restore factory settings on a fujitsu siemens amillo pro
You should be able to fix this simply by inserting the original Cd that came with the computer and following the onscreen instructions.
Or the startup disks (if created) when you first used your laptop.
Alternatively If you do not have the one that came with your computer then you should be able to purchase one from ebay quite easily, and then insert it and follow the onscreen instructions.
I hope this helps you, Chris
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased.
Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
hope this helps
