Question about Nintendo Wii Console
What will happen if it is plugged into a 220 volt AC
I plugged the Wii into a 220 volt AC outlet and something has happened. What will happen if it is plugged into a 220 volt AC adapter. I wasn't given a 220 volt AC adapter
  • aacoler Apr 10, 2009
    I also plugged in my 110 Wii that I bought in the States into a 220 outlet. I ordered a new AC adaptor figuring that this would resolve the issue but now I am not so convinced. Do you think that I messed up the actual console?
    Novelist:
  • 111 Answers
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Posted on Oct 28, 2008
I bought my wii in singapore. the wii says 120V, but here in sri lanka the voltage is 220. without reading this i plugged in the wii. the red light came but before i activated it, i heard a BOOM from the...
It is possible that your power supply fried but everything else is still ok. Something like this could happen during a lightning storm. If you know someone with a wii, try to use their ac adapter (with a 120V adapter). If this works, then you just need a new power supply which is much cheaper.
Sep 01, 2011 | Nintendo Wii Console
The Wii console will not turn on. What could be the problem? I have tried plugging into diff outlets and nothing.
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surpised Nintnedo didn't cover this in theowners manual FAQ, considering it happens almost every time there is apower surge or the power goes out, etc.
Even if it's hooked upto asurge protector, this happens. Power comes back on, but the Wii appearsdead. It won't turn on, and the LED indicators won't light. If therewas a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter2_bing.gif,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surgeprotector outlet. Don't unlpug it from the Wii, it has to be at theoutlet. You have to kill power to the adapter.
Unlpug it fromthe wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuittime to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
My Wii stopped working. Nothing lights up.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
My nintendo has no power going to it even tho the a/c adapter is hooked up
You'll need to unplug the AC adapter from the wall outlet and leave in unplugged for 5- or 10 minutes or so. Unplugging it from the Wii does no good.
This is a common problem with the Wii. As I said, I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked upto a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
I cannot get the power to wii console.all connections are ok
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Dec 03, 2009 | Nintendo Wii Console
Wii work for 3 weeks will not turn on .
There is no light on the front, correct? No red, yellow or green?
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 30, 2009 | Nintendo Wii Console
My wii will not turn on, I have never had a problem with it before. I checked all of the plugs and everything seems great except it will not turn on.
It seems every 5th problem I see is this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii or in the Owner's Manual.
Power will come back on, or you'll go to turn the Wii on one day, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 29, 2009 | Nintendo Wii Console
Everything is plugged in, and it wont turn on
It seems even 5th or 6th problem is this. The AC adapter needs to be reset. Unplug it from the wall outlet for 5 to 10 minutes (NOT from the Wii, it HAS to be from the wall outlet).
Nov 22, 2009 | Nintendo Wii Console
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
Nov 15, 2009 | Nintendo Wii Console
Wii worked fine yesterday. Will not power up
This is a common problem with the Wii. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. It happens almost every time there is a power surge or the power goes out, etc.
Nov 14, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
907 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
