Question about Xerox Office Equipment & Supplies
Error 124-315 xerox wc5230
Me salio este error 124-315 en la copiadora xerox wc5230 me podrían ayudar con lo solucionó gracias
  • 23 Answers
SOURCE: PROBLEMAS CON LA COPIADORA
hello . sorry but your problem is the laser polyigon is defective. u need to change it. i`m an ricoh technician. sorry
Posted on Feb 02, 2011
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
  • 4869 Answers
SOURCE: Saludos, compre en ebay.usa un combo de radio cd y
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Posted on Feb 01, 2010
  • 119 Answers
SOURCE: Tengo un horno microondas sharp modelo R-3A85
sorry I cant speak spanish
Posted on Feb 15, 2010
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Quiero saber que significa el codigo P 0172, tengo problemas con las revoluciones del motor, se me apaga el motor cuando esta en baja, lo puse en la computadora y primero me *** P 0496, ya esa piesa la...
B?sicamente esto significa que un sensor de ox?geno en el banco 1 detecta una condici?n de rica (muy poco ox?geno en los gases de escape). En V6/V8/V10 motores, el Banco 1 es la parte del motor que tiene el cilindro # 1.
Nota: Este DTC es muy similar al P0175 , y, de hecho, su veh?culo puede mostrar dos c?digos al mismo tiempo.
Los s?ntomas: No m?s que probable que observa cualquier problemas de manejo, aunque puede haber s?ntomas como un fallo de encendido.
Un c?digo P0172 puede significar que uno o m?s de los siguientes ha ocurrido:
El MAF (flujo de masa de aire) del sensor est? sucio o defectuoso. Nota: El uso de filtros "aceitado" el aire puede causar que el MAF se ensucie si el filtro est? m?s aceitada. Tambi?n hay un problema con algunos veh?culos, donde los sensores MAF fuga del material de silicona para macetas utiliza para proteger los circuitos.
No puede haber una fuga de vac?o.
Podr?a haber una presi?n de combustible o un problema de entrega
Las posibles soluciones son:
Inspeccione todas las mangueras de vac?o y PCV, reemplazar si es necesario
Cleanthe MAF sensor. Consulte el manual de servicio para su ubicaci?n si necesita ayuda. Me parece que lo mejor es sacarlo y rociarlo con un limpiador de electr?nica o limpiador de frenos. Aseg?rese de que est? cuidado de no da?ar el sensor de MAF, y aseg?rese de que est? seco antes de volver a instalar
Inspeccione las tuber?as de combustible para las grietas, fugas o pellizcos
Revise la presi?n de combustible en la l?nea de combustible
Revise los inyectores de combustible, que puede estar sucio. El uso de combustibles m?s limpios de inyecci?n o hacer que una limpieza profesional / reemplazado.
Compruebe si hay una fuga de escape antes del sensor de ox?geno primero (esto es poco probable que la causa del problema, pero es posible)
Detalles adicionales a traves de este enlace: ODB Fault Codes - Codigos de Falla
Suerte.
Sep 26, 2011 | 2005 Chevrolet Colorado
Ola tengo problema kom el wifi estoi konectado pero me dice k no estoi konectado komo puedo sanar ese error porfavor
Hay un sin f?n de posibles soluciones, pero lo basico es que cheques lo siguiente:
1) Aseg?rate que est?s usando la clave correcta.
2) Reinicia la computadora e int?ntalo de nuevo.
3) Es probable que estes muy lejos, ac?rcate.
4) Reinicia el mismo modem o router, s?lo desc?nectalo de la corriente y vu?lvelo a conectar. Impresionantemente esto resuelve los problemas much?simas veces.
Servir?a saber que clase de ?cono de conex?n inal?mbrica tienes en la barra de tareas.
May 18, 2011 | Computers & Internet
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
Apr 22, 2011 | Nikon COOLPIX S8000 Digital Camera
Estoy buscandao el sensor po 700 y el 846 que puede ser
P0700 - Transmission Control System malfunction
El código P0700 se describe mal funcionamiento del sistema de control de transmisión. Básicamente lo que esto significa es que un mal funcionamiento ha sido detectado en la transmisión y los componentes asociados. Hay buenas noticias y malas noticias. La buena noticia es que podría ser cubierto por la garantía. No aclaró si su vehículo está en garantía, ser conscientes de que aún puede tener cobertura de la garantía en esto desde el coche está a sólo 3 años de edad. La mala noticia es que el código P0700 realmente significa que hay códigos de transmisión específica que no puede acceder con un lector de código de regular. Hay una parte llamada TCM - Módulo de control de la transmisión que funciona en forma similar a su PCM. La medicina tradicional china se encarga de la transmisión eléctrica de "cosas" y que almacena más códigos de transmisión.
Si quieren seguir el tema usted mismo, usted tendrá que conseguir sus manos en un lector de código de fin más alto, o llévelo a su distribuidor o una tienda de la transmisión para obtener los códigos de transmisión real de problemas leer. Personalmente, le recomendamos que obtenga una tienda de leer los códigos para usted. Los códigos de los otros códigos de comunicación, le recomendamos que borre los códigos después de corregir el código P0700 y ver si vuelven, que podría estar relacionado con el tema "principal" de transmisión. La otra buena noticia es la solución para este sólo puede ser una actualización de software que el distribuidor puede hacer.
P0846 -
Trans Fluid Press Sens/Switch A Circ Range/Perf
espero ayudar.
Mar 06, 2011 | 2002 Chrysler Concorde
Mi proble es que en la pantalla superior aparece las letras oooofeoo
Hola,
Bienvenido a Fixya. Para fijar el asunto con sus D que consiguen 0000FE00 siga s?lo los pasos abajo.
1. Comience su DSi y la espera hasta que la Bater?a sea Vac?a. (Teniendo una Bater?a vac?a baja el tiempo de inicializar. Las D consiguieron dos memorias r?pidas internas que ambos son da?ados cuando tiene este error. Con la Bater?a baja el repuso uno consigue carg? mientras el otro puede no en la misma velocidad)
2. ¿Quita los Cerrojos y extrae la Bater?a para alrededor de 1,5 horas.por qu? que hicimos esto? Toda la Electricidad debe para no ser fuera del Sistema de asegurarse de que s?lo consigue la Informaci?n de Bootup de la Pastilla que fue repuesta y del otro, si el otro le podr?a enviar es informaci?n, nosotros todav?a tendr?amos el Error.
3. Vuelva a instalar su Bater?a.
4. Debe ser r?pidamente ahora: Inserte su Tarjeta Did?ctica, y comience su DSi.COMIENZA la Aplicaci?n usted utiliz? la ?ltima vez, antes que el Error pareciera y lo cierre legitimadamente. En caso de que del Emulador de SNES de SuperCard DSTWO, apriete s?lo el Bot?n de la Salida. Otras Tarjetas Did?cticas como la necesidad R4i para ser suaves repuestas al men? de la tarjeta did?ctica, y la necesidad de inicializar la rom de alg?n juego.
5. -No Necesario pero justo se siente un poco m?s seguro- Formatear su NDSi.
6. Cargue su Bater?a y disfrute de jugar sus Sistemas de NDSi otra vez.
- Cambiando Generalmente bater?a fijar? este problema para mejores resultados sigue los pasos antes mencionado.
Trabaja para m? y para otros optimistamente wil fija su problema. Si tiene preguntas permiten por favor que s?.
Gracias por utilizar Fixya
Mar 05, 2011 | Nintendo DSi Red Console
Codigos marca P0300 P0113 P0125 P0123 P0335 P0351 P0358 P1258
Losiento, mi espanol es no perfecto. S? c?mo hablarlo algo correctamente, pero yo no lo puedo deletrear repara, as? que tuve ayuda del Internet, espere que esto haga desde entonces.
P0300- esto es un fallo de tiro aleatorio, la necesidad de reemplazar sus buj?as y verificar sus rollos
P0113- esto es probablemente un malo 02 sensor, verifica el sensor r?o arriba en el compartimiento de motor
P0125-El motor no consigue suficiente caliente, su termostato probablemente es atascado abierto, esto debe ser reemplazado.
P0123- Algo est? equivocado con el sensor de posici?n de v?lvula de admisi?n, verifica los alambres esto tambi?n podr?a ser una computadora da?ada.
P0335- esto es el sensor de posici?n de manivela, otra vez, verifica el alambrado
P0351-esto tiene que ver con tiempo de ignici?n, consigue este averigu? por un profesional
P0358-El rollo malo posible en el cyclinder #1. Verifique el rollo conmutaci?nlo con un cilindro diferente, vea si consigue el mismo problema con el otro cilindro. Podr?a ser relacionado a la buj?a mala tambi?n.
P1258-La temperatura relacion? otra vez, debe irse con el reemplazo del termostato
Todo en total, no parece demasiado grave. Yo tambi?n limpiar?a el cuerpo de v?lvula de admisi?n con limpiador de cuerpo de v?lvula de admisi?n, con la bater?a desconectada. Debe ser brillante, cuando terminado, el viaje alrededor de durante 20 minutos con todos los accesorios de reponga la computadora. Tambi?n, trate buj?as de aire acondicionado Delco que utiliza modelan #41-103, estos motores adoran ?stos.
Feb 01, 2011 | 2004 Chevrolet TrailBlazer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ¿Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
Tengo un stratus 96 motor 2.4 y lo que le pasa es que me esta gastando mucha gasolina lo lleve a escanear y lo unico que me arrojo fue el codigo p0171 quiero saber si tiene algo que ver y como puedo...
DTC P0171 System Too Lean (Bank 1)
Básicamente esto significa que un sensor de oxígeno en el banco 1 detectó una condición de escasez (cantidad de oxígeno demasiado en el escape). En los motores V6/V8/V10, el Banco 1 es el lado del motor que ha cilindro N º 1. Nota: Este DTC es muy similar al P0174, y de hecho su vehículo puede mostrar tanto los códigos a la vez.
Síntomas: Usted más que probable que no nota ningún problema de conducción, aunque puede haber síntomas como la falta de poder, la detonación (detonaciones), y / o una vacilación / aumento en la aceleración.
Causas: Un código P0171 puede significar que uno o más de los siguientes paso:
  • El MAF (flujo de aire masivo) del sensor está sucio o defectuoso. Nota: El uso de "aceitado" filtros de aire puede causar que el MAF se ensucie si el filtro está más aceitada. También hay un problema con algunos vehículos, si los sensores MAF fuga de la silicona para macetas material utilizado para proteger los circuitos.
  • No puede haber un vacío de fugas de aguas abajo del sensor MAF.
P
osibles soluciones:
Las posibles soluciones incluyen:
  • En la gran mayoría de los casos, sólo tiene que limpiar el sensor MAF hace el truco. Consulte su manual de servicio para su ubicación si necesita ayuda. Me parece que lo mejor es quitarlo y pulverizarla con limpiador de electrónica o limpiador de frenos. Asegúrese de que está cuidado de no dañar el sensor de MAF, y asegúrese de que esté seco antes de volver a instalar
  • Inspeccione todas las mangueras de vacío y PCV, sustituir si es necesario
  • Compruebe si hay un filtro de combustible sucio y la presión del combustible adecuado
Hope helps (espero que esto sea de ayuda, recuerde calificar esto).
Jul 31, 2010 | Dodge Stratus Cars & Trucks
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Que significa el error 0X4001100200001005 en una restauracion de
Acabo de recibir el mismo mensaje de error en mitad de una restauracion de pc. La solucion en mi caso:
1) Desonectar el cable de alimentacion y encender el pc para que se descargue de toda corriente, volver a conectar la alimentacion.
2) Limpiar el CD de restauracion (con el CD sucio no lee y da error) e introducirlo en la bandeja CD/DVD
3) Encender el pc y enseguida oprimir F12 para que arranque con CD/DVD
4) Esperar que eso lo solucione
Jul 06, 2009 | E-Machines (T2958) PC Desktop
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
