Question about General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane
My GE Profile RO system runs constantly from the supply through the system and into the drain. What could be the cause?
The system stopped working completely so i replaced the filters. No change so I removed the diaphram to look for a problem. Now the supply runs constantly into the RO and back out to the drain under the sink???
4 Suggested Answers
SOURCE: GE smartwater R.O. system leaking out weep hole
Same exact problem started for us last night. (Same model, installed by me about four+ years ago) Water was really coming out of the weep hole, and didn't stop until I shut it off at the valve. This happened once before, and all I had to do was clean the drain line adapter, because it gets full of gunk from the disposal over time. But this time that did not do the trick. (Plus there was not all that much gunk this time....) So I was baffled for awhile but came up with this solution.
I hooked up a small length of clear tubing to my cheap-o tire inflater/air compressor. Put the clear tube against the weep hole. Turned on the compressor, and VOILA!, a bunch of gunk that was clogging the drain tube came out. I think when this tube, or the drain line adapter gets clogged, it causes water to go out the weep hole instead of down the drain. (If you don't have a small compressor, then theoretically there is enough air pressure from something like a bicycle pump, and this solution *might* work with one of those. But if you try this, of course only use the DOWNWARD (air-going-outward) pump action...pulling up (inward) would force the clog deeper up the drain tube)
Posted on Oct 02, 2009
SOURCE: GE smartwater R.O. system making noise from hole on side of fauce
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
fwsweb
  • 28 Answers
SOURCE: Indicator lites on the GE RO facuet do not lite.
If you have concern about the quality of water being produced by your RO system, I would recommend using a handheld or in-line TDS meter. Instead of a red or green LED, these meters will give you a reading of TDS (total dissolved solids) in parts per million (PPM). With either of these meters you are taking a reading from the feed water to the system as well as from the product water, you then can calculate the percentage of solids being rejected by the RO system (using the simple equation listed below). This way you will know exactly how well the RO system is working and when the membrane needs to be replaced. I have included links below to our selection of handheld and in-line TDS meters as well as an instructional video that explains how to use a handheld TDS meter.
Here is a helpful link that includes the formula for calculating percent rejection.
http://www.freshwatersystems.com/t-measuretds.aspx
Handheld TDS Meters - http://www.freshwatersystems.com/c-253-handheld-meters.aspx
In-line - http://www.freshwatersystems.com/c-255-in-line-monitors.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Posted on Apr 21, 2010
My GE dishwasher won't stop running what do I do
Check the internal of dishwasher because maybe you have leakage.This leakage stops the program and causes the continuing operation of the drain pump.
Sep 13, 2013 | GE Profile PDW8400J Built-in Dishwasher
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
6 stage ro system under counter style will not stop draining or producing ro water at all I removed unit changed 3 pre filters and a post polisher now I gotta problem How long will this unit run to fill...
If the RO is not shutting off and there is no water from tank there are several things to check.
1. The product water tank is probably low on air. The tank may be full but no water will come out. Put enough air in tank to force out all the water then reset air pre-charge to 7psi for 3 gallon tank.
2. The capillary tube / check valve of RO system is bad. This puts back pressure on membrane to help create water.
3. The Automatic shutoff is not working, causing the unit to run constantly.
I would have to know what model RO it is to narrow down the problem further.
Depending on the Membrane production 10, 25 gpd, etc. and the TDS of water it may take 24 hrs to fill the tank.
RJ
Oct 07, 2011 | Culligan Under Sink Water Filter
I have a GE PROFILE R/O System with a chrome dispenser; I need a brushed nickel dispense; where can I get one???
An RO drinking water air gap faucet would be the ideal faucet to purchase for your RO system. Here are a few options you can choose from that may come in brushed nickel: http://www.freshwatersystems.com/c-821-ro-drinking-water-air-gap-faucets.aspx
Jul 31, 2010 | General Electric Profile Smartwater Ultra...
A drain tube in the water dispensing module constantly has some water flow. What is the purpose of this drain and how can I eliminate the water loss.
A reverse osmosis system drinking water system will waste a certain amount of water for every gallon it produces.
1. The higher the TDS (total dissolved solids) the higher the ratio of waste water to product water.
IE: An RO on TDS of 1000ppm may require 7 or more gallons of water to waste to 1 gallon of product water. TDS of 100ppm will have about 3 gallons of waste to each gallon produced.
2. It also depends on the Membrane capacity. Membranes for residential RO systems come sized from 7-75 gallons per day. If you are a heavy water user and have a low producing membrane the RO may not shut off until it gets to rest at night and fill the tank.
3. There can also be a problem with the automatic shutoff on the RO. When the tank fills up and the pressure equalizes across the system the ASO (which is just a simple diaphram system) shuts the water off to the system.
4. If there is not enough pressure in the RO tank the tank may fill up but there may not be enough back pressure to shut the ASO off. So the waste and product water go down the drain and it runs constantly.
RJ
May 21, 2010 | Culligan Under Sink Water Filter
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
May 28, 2009 | General Electric Profile Smartwater Ultra...
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Feb 13, 2009 | General Electric Profile Smartwater Ultra...
General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Logo
594 people viewed this question
Top General Electric Water Filters & Coolers Experts
Tom Chichester
Are you a General Electric Water Filter and Cooler Expert? Answer questions, earn points and help others
