What is the output voltage of the ac adapter.
  • aquaknot2000 Feb 28, 2012
    Thanks but I got the ansewer from the manufactuer--Buslink.
Whats the model number of the item. The easiest way is to look ta the bottom of the device by US law they must list it. It should be somewhere near the serial number/model number.
Posted on Feb 26, 2012
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
When connected to AC mains and switched on there was no sign of glowing led displaying charger is "ON"
Use multimeter to check output of AC Adapter. If no DC output at required voltage you should replace adapter; available after market units sell for $10 to $15 delivered.
Jan 03, 2014 | Compaq 239427-001 Laptop AC Adapter...
Dead
No voltage output signifies a BAD AC Adapter. Search eBay with part number, then order a GENERIC AC Adapter with low price of $6.80 including shipping.
Toshiba 1905-s301 wont run on just ac power
Check your AC Adapter for voltage output using a multi-meter. If voltage is lower than stated replace Adapter. When replacing adapter verify Amperage is same before purchase.
Dec 18, 2013 | Toshiba Satellite 1905-S301...
We have an Acculab V-200 electronic balance here at school. The AC adapter was misplaced, however one with a 12 volt output was found. It fits the balance but I am afraid to plug it in since the unit can...
re: Acculab V-200 Digital Scale
The original AC acpater is rated at 12VDC 300mA output. It is unregulated (i.e. the output voltage is about 16-17V with no load)
The centre pin is NEGATIVE, which is the opposite of "most" AC adapters.
(Acculab model number is 41-12-300D, for the 120V 60Hz version)
Aug 16, 2011 | Health & Beauty
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
