Question about Kenmore Dishwashers
Replace bosch shu 6800 soap dispenser
How do i replace the soap dispenser
  • 311 Answers
SOURCE: Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Posted on Nov 28, 2008
SOURCE: bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Posted on Jan 13, 2009
  • 21 Answers
SOURCE: Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Posted on Jul 20, 2009
  • 457 Answers
SOURCE: Bosch dishwasher soap dispenser
all you have to do is take a flathead screwdriver and look at the dispenser it has a locking metal around thecase where the dispenser goes. it a press in and listen to it click thats when you know that section is in.the plastic around the dispenser is the section where it snaps in. also unplug the dispenser. its only one plug in. very easy but atrick that i use is make sure the rubber gasket is lubricated with something like dish soap.when installing it you have to push hard and listen for the snaps .nyc appliance repair can handle at 1-888-692-1055 based in nyc
Posted on Feb 26, 2010
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher soap dispenser doesn't open
Welcome to FixYa.
This has become a popular issue with the newer style Bosch dishwasher, and I don`t know if this is the case in your situation, however if using "cubed" or "gel pack" type detergents the dispenser will often get stuck therefore preventing opening.
At a recent service seminar for the Bosch SHX/SHE "Evolution/Ascenta" series dishwasher`s I attended, it was suggested if a client is using the "cubed/gel pack" or even liquid detergent either place the cubes directly into the bottom of the dishwasher or in the case of liquid, switch to powder detergent since both liquid and cubes seem to have an issue of causing this problem.
I understand from experience of presenting this with many clients it may at first appear inconvenient or unacceptable, and many will balk at the idea. Unfortunately it is a reality and no physical repair to the machine will remedy the issue.
Try the suggestion and let me know how you find the unit performs. In my experience the unit actually will perform better actually, as the detergent`s nowadays without "phosphate" require a longer period to dissolve completely and therefore often don`t work nearly as well when being dispensed from the "cup/dispenser".
I`ll watch for your reply on the result or if you need further assistance. Thank you for choosing FixYa. Please take a moment to rate the info provided here today and a testimony if you feel it`s warranted.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 06, 2010
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Water does not get pumped out of dishwasher
I have had this problem a few times. For me all I had to do was unscrew the vent/overshow knob on the sink and clean out the vent. Because the vent is clogged, it does not allow the water to flow out. Clean out the debri and screw the vent cap back on- should work fine.
Aug 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
How do we replace soap dispenser for Bosch SGS5302GB/07
Unplug the unit. Open the DW door .remove screws.Carefully place it aside. you are going to see soap dispenser unit. remove the wire harness carefully, remove the screws. Replaced it with new one. so simple. assemble back the door panel.
Jul 23, 2008 | Bosch Dishwashers
Bosch shu 9950
Feb 17, 2008 | Bosch SHU9950 Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher still some soap left on dishes
Most of the causes of the problem that you are describing are related to the way the dishes are loaded in the unit. To test this, run it empty and see if the dish soap dissipates.
Mar 17, 2017 | Bosch SHU3305 Dishwasher
Dishwashers Logo
32 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
