Question about Fuji FinePix F601 Zoom Digital Camera
Black LCD Screen
The LCD screen on my camera is very dark, like when the brightness button on a TV has been turned right down. You can still see images, but through a very dark, grey fog. I can still take pictures and download them, but they are very dark. The camera hasn't been dropped or damaged: I took a picture, then what appeared to be TV interference appeared on the screen, then black. Can anyone help? Fuji want £100 minimum to fix it, so until I come into some money, the camera will have to stay in its box. Any suggestions will be gratefully received.
  • kkanwal May 18, 2009
    my finepix F601's LCD is not working properly .. left most of the lcd is showing pic but the centre and the right part of LCD is BLACK ..please help me how i can fix this problem ?
Faulty main or secondary board. Could also be faulty light sensor or iris. Not a user fixable problem unless you can get another f601 with a broken lens etc with good boards (to replace boards). Or a dead camera with good lens assembly (contains iris).
Very fiddly if you have the parts!!!!!!
Best advise is to sell it as faulty on ebay.
Posted on Jul 05, 2008
In my w180 image is clear and bright in the LCD screen but when i downloaded the images to my PC it shows poor lighting and dark images pls help me
The lcd screen on your camera is back-lit and shows a brighter picture than the one you actually take. If you can turn down the screen brightness that may help. You could also raise the "exposure compensation" setting and experiment until you find a setting you like.
Oct 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
My ESA PDP4294LV1 flashes when the screen is too bright....
Plasma? LCD? DLP? LP? CRT? What is your viewing candy?
I need to know what type of t.v you have and model and everything before i can answer that question, otherwise, i cant answer it for you, sorry friend :)
Mar 09, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Samsung i5 camera
Try the following and see if this helps:
menu tab.
Aug 12, 2008 | Samsung Digimax i5 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Canon A520 - LCD screen works but very very dark!
Yes I beleive in the tools menu there is an LCD brightness option. Hit menu and to the right twice for this menu I think. (maybe in the shooting menu though.)
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Fuji FinePix F601 Zoom Digital Camera Logo
145 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
